Duplicate ViewSheet across Documents
I've been looking for the process of duplicating sheets from a source document to a destination document.
I was able to find the way how to duplicate drafting views from the DuplicateViews project in SDK, but failed to modify the codes for ViewSheets.
Should I copy title blocks first before duplicate sheet elements? Please adress me the steps I need to go through to solve this problem.
I would like to implement the same way as "Insert >> Insert from File >> Insert Views from File >> Sheets only"
Please let me know.
you should first retrieve the titleblock (familyinstance), then loop over the views to see what views are on the sheet, then create a new sheet and then create duplicates of the views and place them on the sheet.
