DRAW LINE VISIBLE ON SCREEN
rodrigohbm
Message 1 of 17
rodrigohbm
is there any way to create a line
when the first point appears
then click on the second point
I have the following code
with which I **** the first point and then the second
and the line is drawn.
  Public Sub CrealineaPickpoint()
      Dim doc As Document = Me.Application.ActiveUIDocument.Document
      Dim uidoc As UIDocument = Me.Application.ActiveUIDocument
      Dim startPoint As XYZ = uidoc.Selection.PickPoint("PickPoint One")
      Dim directionPt As XYZ = uidoc.Selection.PickPoint("PickPoint Two")
        Dim detailline As DetailLine
        Dim t As Transaction = New Transaction(doc, "Create Detail Line")
        If True Then
            t.Start()
            Dim line As Line = Line.CreateBound(startPoint, directionPt)
            detailline = TryCast(doc.Create.NewDetailCurve(doc.ActiveView, line), DetailLine)
            t.Commit()
        End If
        TaskDialog.Show("Length", detailline.id.tostring)
     End Sub
the idea is to create the line
as the detail line command
in this way the user can interact
with the application to see the direction of the line
I was looking at information in several places
even in SDK but nothing appears
I appreciate the help.
regards
Replies (16)
Message 2 of 17
jeremytammik
What you are asking for is called a 'rubber band' or 'rubber banding'.
Nope, sorry, afaik the Revit API does currently not provide access to this functionality.
You can raise a wish for it in the Revit Idea Station, if you like, or vote for an existing wish, if one exists.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 17
rodrigohbm
Hello
analyzing the subject
you can take care of the family  Detail Item line based
since it is requesting the insertion point
and then the second point to end
there will be some example using
regards
Message 4 of 17
l.virone
I had the same UI problem and I've used these two functions inside a loop which create a line where the mouse is, refresh, and delete the line every 0.1 seconds until the user choose the second point. A little Tricky but it worked fine for me and Revit seems to execute these 2 functions very fast.
uidoc.RefreshActiveView();
doc.Regenerate();
Good Luck
Message 5 of 17
jeremy_tammik
Wow, thank you very much for the interesting suggestion. Do you use a model line or a detail line? Could you share a bit more of the code? This is an interesting approach to creating transient graphics. Other approaches use the  IDirectContext3DServer functionality or the temporary InCanvas graphics API:
Message 6 of 17
l.virone
Hi @jeremy_tammik,
I didn't use it to create a line, but this trick will work with anything. I's like creating elements each mouse movement, refresh, delete the created elements and replace them with new ones. It can technically works with anything, model or detail elements and it's easy to implement because you just need to call the two methods.
It looks like:
bool done = false;
List<ElementId> temp = new List<ElementId>();
While(!done)
    doc.Delete(temp);
    temp = new List<ElementId>(); //prevent try to delete elements previously deleted
    //Create your temp elements and put their IDs in "temp"
    //Don't forget to set "done" at "True" when the user has finished
    doc.regenerate();
    Thread.Sleep(500); //You can change the amount of refresh time (milliseconds)
//Your final elements are in "temp"
EDIT: "Thread.Sleep()" works fine, but I prefer to use events to choose when refresh the result so I have more control and I don't reload if the user didn't do anything.
Message 7 of 17
jeremy_tammik
Thank you for your nice explanation. Shared it on the blog:
https://thebuildingcoder.typepad.com/blog/2023/03/lookup-ideas-jigs-and-acc-docs-access.html#3
Message 8 of 17
l.virone
hi @jeremy_tammik
I'm happy for my first publication in your blog!
For your information, I used this method to allow my colleagues to print quickly at different scales and formats in a dynamic way. For this I temporarily drew a titleblock (using DetailLine and Text) with the project information, then I exported to PDF, and finally I never committed the transaction. It's a lot more complex than one signle line, but thanks this method works with any Revit element.
Best regards,
Virone Lorenzo
Message 9 of 17
Chuong.Ho
It can be work with DirectShape
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using Line = Autodesk.Revit.DB.Line;
using Point = Autodesk.Revit.DB.Point;
var Doc = commandData.Application.ActiveUIDocument.Document;
using TransactionGroup trang = new TransactionGroup(Doc, "test");
        trang.Start();
        XYZ a = UIDoc.Selection.PickPoint(ObjectSnapTypes.None);
        SetPoint(a);
        XYZ b = UIDoc.Selection.PickPoint(ObjectSnapTypes.None);
        SetPoint(b);
        SetLine(a,b);
        XYZ p1 = UIDoc.Selection.PickPoint(ObjectSnapTypes.None);
        SetPoint(p1);
        XYZ p2 = UIDoc.Selection.PickPoint(ObjectSnapTypes.None);
        SetPoint(p2);
        bool isSamSide = IsSamSide(p1, p2, a, b);
        MessageBox.Show(isSamSide.ToString());
        trang.Assimilate();
// visualize a point
void SetPoint(XYZ xyz)
            using (Transaction tran = new Transaction(Doc, "Add point"))
                tran.Start();
                Point point1 = Point.Create(xyz);
                DirectShape ds =
                    DirectShape.CreateElement(Doc, new ElementId(BuiltInCategory.OST_GenericModel));
                ds.SetShape(new List<GeometryObject>() {point1});
                tran.Commit();
// visualize a line
void SetLine(XYZ x1,XYZ x2)
    using (Transaction tran = new Transaction(Doc, "Add line"))
        tran.Start();
        Line line = Line.CreateBound(x1, x2);
        DirectShape ds =
        ds.SetShape(new List<GeometryObject>() {line});
        tran.Commit();
Chuong Ho
Message 10 of 17
l.virone
Hi@Chuong.Ho
Yes, but I think your method only works with simple geometric shapes, am I wrong ? Can your method be used to create elements like Text, Wall, Dimension, etc. ?
Thank you
Message 11 of 17
jeremy_tammik
Brilliant! Added that as well! Thank you!
Message 12 of 17
BHamlet
@Chuong.Ho
Just wondering if you wouldn't mind sharing the isSamSide method?
@l.virone
Does this constant updating with the line make the Element ID climb during use?
Bob
Message 13 of 17
l.virone
Hello @BHamlet,
You are right, one solution I think to prevent anything wrong is to divide the problem into 2 transactions :
  1. First one to view things, this transaction will never be committed.
  2. Second one to create the Elements which need to stay into the model (will be committed).
But it seems the Elements created but never commited in the first transaction have increased the ElementId value 😢... I don't know what happen if a Revit model reach the max Integer value and if Autodesk have a way to prevent problems. However, the int 32 limit is 2,147,483,647 and 64 limit is 9,223,372,036,854,775,807 so with Int64 we have some space to work.
EDIT : A solution which works is to create one line and update the coordinate of it's points using the same view update method. You can edit the geometry of an existing DetailLine or ModelLine like this : myDetaiLine.GeometryCurve = Line.CreateBound(new XYZ(1,0,0), new XYZ(0,1,0));
My solution is to see the "Element ghost" while interacting but take care using it. The DirectShape method prevent the ElementId increase BUT it'll not allow you to see the "line ghost" while moving your mouse. Differents methods with differents results and problems, it depends of what you need.
Thanks @BHamlet for your thought !
@jeremy_tammikmaybe you should add this warning in your blog. I don't know if ElementId are Int64 in the 2024 API.
You can check those 2 links to know more about ElementId size limit in Revit :
https://forums.autodesk.com/t5/revit-api-forum/is-there-a-maximum-integer-value-of-an-element-id-in-...
https://thebuildingcoder.typepad.com/blog/2022/11/64-bit-element-ids-maybe.html
Message 14 of 17
Chuong.Ho
This is method issamside :
bool IsSamSide(XYZ p1, XYZ p2, XYZ a, XYZ b)
        XYZ cp1 = (p1 - a).CrossProduct(b - a);
        XYZ cp2 = (p2 - a).CrossProduct(b - a);
        return cp1.DotProduct(cp2) >= 0;
Chuong Ho
Message 15 of 17
jeremy_tammik
The What's New in the Revit 2024 API document includes the official statement about 64 bit element ids in Revit 2024:
https://thebuildingcoder.typepad.com/blog/2023/04/whats-new-in-the-revit-2024-api.html#4.1.2
I totally agree that it is better to try to reuse your transient geometry if possible rather than recreating it from scratch and consuming element ids for nothing.
Message 16 of 17
jeremy_tammik
Interesting observation on consuming the element id space even when the transaction is not committed. I asked the development team for their thoughts on that for you.
Message 17 of 17
vanlion
I almost got the solution for you i think with the help of "DirectContext3DService and the "DuplicateGraphics" SDK sample. The only thing i'm not happy with is that the first point is picked with "uidoc.Selection.PickPoint("Pick First Point:")" So you have the Revit Snap options but the second point is with a custom made "Click" code as you can see below. It would be nicer if the second point also can be done with a "uidoc.Selection.PickPoint("Pick Second Point:")"  but if you use that the "transient" line doesn't update anymore in the while loop. Maybe @jeremy_tammik  or @Chuong.Ho got a solution to make this last step work?
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.DB.ExternalService;
using System.Runtime.InteropServices;
using PointW = System.Drawing.Point;
using windowsForms = System.Windows.Forms;
using System.Threading;
using System.Diagnostics;
using System.Windows.Interop;
using System.ComponentModel;
using System.Reflection;
#endregion
namespace SharpLion_BIM_Toolbar
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class DuplicateGraphics : IExternalCommand
        List<RevitElementDrawingServer> m_servers;
        HashSet<Document> m_documents;
        UIDocument m_UIdoc;
        UIApplication m_uiApp;
        private IntPtr rWindow = IntPtr.Zero;
        XYZ m_P1;
        private List<Line> LineList = new List<Line>();
        public Result Execute(
        ExternalCommandData commandData,
        ref string message,
        ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            m_servers = new List<RevitElementDrawingServer>();
            m_documents = new HashSet<Document>();
            m_UIdoc = uidoc;
            m_uiApp = uiapp;
            this.rWindow = GetActiveWindow();
            try
                m_P1 = uidoc.Selection.PickPoint("Pick First Point:");
            catch (Exception ex)
            try
                bool done = false;
                while (!done)
                    windowsForms.Cursor.Current = windowsForms.Cursors.Cross;
                    AddRevitElementServer(m_UIdoc, m_P1);
                    var revitHandle = Process
                   .GetCurrentProcess().MainWindowHandle;
                    SetStatusText(revitHandle, "Pick Last Point:");
                    if (GetLeftMousePressed()|| GetEscPressed())
                        i++;
                        if (i == 2)
                            i = 0;
                            done = true;
                            unregisterServers(doc, true);
            catch { }
            return Result.Succeeded;
        private int i = 0;
        public void AddRevitElementServer(UIDocument uidoc,XYZ p1)
            LineList.Clear();
            XYZ p2 = GetMousePosition();
            if (p1.DistanceTo(p2) > 0.01)
                LineList.Add(Line.CreateBound(p1, p2));
                m_uiApp.ActiveUIDocument.RefreshActiveView();
               // XYZ p3 = m_UIdoc.Selection.PickPoint("Pick Last Point:");
                // Create the server and register it with the DirectContext3D service.
                ExternalService directContext3DService = ExternalServiceRegistry.GetService(ExternalServices.BuiltInExternalServices.DirectContext3DService);
                RevitElementDrawingServer revitServer = new RevitElementDrawingServer(uidoc, LineList);
                directContext3DService.AddServer(revitServer);
                m_servers.Add(revitServer);
                MultiServerService msDirectContext3DService = directContext3DService as MultiServerService;
                IList<Guid> serverIds = msDirectContext3DService.GetActiveServerIds();
                serverIds.Add(revitServer.GetServerId());
                // Add the new server to the list of active servers.
                msDirectContext3DService.SetActiveServers(serverIds);
                m_documents.Add(uidoc.Document);
                uidoc.UpdateAllOpenViews();
        public void unregisterServers(Document document, bool updateViews)
            ExternalServiceId externalDrawerServiceId = ExternalServices.BuiltInExternalServices.DirectContext3DService;
            var externalDrawerService = ExternalServiceRegistry.GetService(externalDrawerServiceId) as MultiServerService;
            if (externalDrawerService == null)
                return;
            foreach (var registeredServerId in externalDrawerService.GetRegisteredServerIds())
                var externalDrawServer = externalDrawerService.GetServer(registeredServerId) as RevitElementDrawingServer;
                if (externalDrawServer == null)
                    continue;
                if (document != null && !document.Equals(externalDrawServer.Document))
                    continue;
                externalDrawerService.RemoveServer(registeredServerId);
            if (document != null)
                m_servers.RemoveAll(server => document.Equals(server.Document));
                if (updateViews)
                    UIDocument uidoc = new UIDocument(document);
                m_documents.Remove(document);
            else
                m_servers.Clear();
                if (updateViews)
                    foreach (var doc in m_documents)
                        UIDocument uidoc = new UIDocument(doc);
                m_documents.Clear();
        private XYZ GetMousePosition()
            UIView uiview = GetActiveUiView(m_UIdoc);
            Rectangle rect = uiview.GetWindowRectangle();
            PointW p = windowsForms.Cursor.Position;
            double dx = (double)(p.X - rect.Left)
              / (rect.Right - rect.Left);
            double dy = (double)(p.Y - rect.Bottom)
              / (rect.Top - rect.Bottom);
            IList<XYZ> corners = uiview.GetZoomCorners();
            XYZ a = corners[0];
            XYZ b = corners[1];
            XYZ v = b - a;
            XYZ q = a
              + dx * v.X * XYZ.BasisX
              + dy * v.Y * XYZ.BasisY;
            return q;
        static UIView GetActiveUiView(UIDocument uidoc)
            View view = doc.ActiveView;
            IList<UIView> uiviews = uidoc.GetOpenUIViews();
            UIView uiview = null;
            foreach (UIView uv in uiviews)
                if (uv.ViewId.Equals(view.Id))
                    uiview = uv;
                    break;
            return uiview;
        [DllImport("user32.dll")]
        static extern short GetAsyncKeyState(int VirtualKeyPressed);
        public static bool GetLeftMousePressed()
            if (GetAsyncKeyState(0x01) == 0)
                return false;
            else
                return true;
        public static bool GetEscPressed()
            if (GetAsyncKeyState(0x1B) == 0)
                return false;
            else
                return true;
        //Set custom bottom text
        static extern IntPtr GetActiveWindow();
        [DllImport("user32.dll",
            SetLastError = true,
            CharSet = CharSet.Auto)]
        private static extern int SetWindowText(
            IntPtr hWnd,
            string lpString);
            SetLastError = true)]
        private static extern IntPtr FindWindowEx(
            IntPtr hwndParent,
            IntPtr hwndChildAfter,
            string lpszClass,
            string lpszWindow);
        public static void SetStatusText(
            IntPtr mainWindow,
            string text)
            var statusBar = FindWindowEx(
                mainWindow, IntPtr.Zero,
                "msctls_statusbar32", "");
            if (statusBar != IntPtr.Zero) SetWindowText(statusBar, text);
And Second Class:
using Autodesk.Revit.DB.DirectContext3D;
using System;
using System.Linq;
using System.Windows.Forms;
    class RevitElementDrawingServer : IDirectContext3DServer
        public RevitElementDrawingServer(UIDocument uiDoc, List<Line> line)
            m_guid = Guid.NewGuid();
            m_uiDocument = uiDoc;
            // m_element = elem;
            m_lines = line;
        public System.Guid GetServerId() { return m_guid; }
        public System.String GetVendorId() { return "ADSK"; }
        public ExternalServiceId GetServiceId() { return ExternalServices.BuiltInExternalServices.DirectContext3DService; }
        public System.String GetName() { return "Revit Element Drawing Server"; }
        public System.String GetDescription() { return "Duplicates graphics from a Revit element."; }
        // Corresponds to functionality that is not used in this sample.
        public System.String GetApplicationId() { return ""; }
        public System.String GetSourceId() { return ""; }
        public bool UsesHandles() { return false; }
        public bool CanExecute(Autodesk.Revit.DB.View view)
            return true;
            //var doc = view.Document;
            //return doc.Equals(this.Document);
        // Reports a bounding box of the geometry that this server submits for drawing.
        public Outline GetBoundingBox(Autodesk.Revit.DB.View view)
            return null;
        // Indicates that this server will submit geometry during the rendering pass for transparent geometry.
        public bool UseInTransparentPass(Autodesk.Revit.DB.View view) { return true; }
        // Submits the geometry for rendering.
        public void RenderScene(Autodesk.Revit.DB.View view, DisplayStyle displayStyle)
            try
                // Populate geometry buffers if they are not initialized or need updating.
                if (m_nonTransparentFaceBufferStorage == null || m_nonTransparentFaceBufferStorage.needsUpdate(displayStyle) ||
                    m_transparentFaceBufferStorage == null || m_transparentFaceBufferStorage.needsUpdate(displayStyle) ||
                    m_edgeBufferStorage == null || m_edgeBufferStorage.needsUpdate(displayStyle))
                    CreateBufferStorageForElement(m_lines, displayStyle);
                // Conditionally submit line segment primitives.
                if (displayStyle != DisplayStyle.Shading &&
                    m_edgeBufferStorage.PrimitiveCount > 0)
                    DrawContext.FlushBuffer(m_edgeBufferStorage.VertexBuffer,
                                            m_edgeBufferStorage.VertexBufferCount,
                                            m_edgeBufferStorage.IndexBuffer,
                                            m_edgeBufferStorage.IndexBufferCount,
                                            m_edgeBufferStorage.VertexFormat,
                                            m_edgeBufferStorage.EffectInstance, PrimitiveType.LineList, 0,
                                            m_edgeBufferStorage.PrimitiveCount);
            catch (Exception e)
                MessageBox.Show(e.ToString());
        // Initialize and populate buffers that hold graphics primitives, set up related parameters that are needed for drawing.
        private void CreateBufferStorageForElement(List<Line> transientLines, DisplayStyle displayStyle)
            m_edgeBufferStorage = new RenderingPassBufferStorage(displayStyle);
            foreach (var edge in transientLines)
                // if (edge.Length > 1e-06)
                    IList<XYZ> xyzs = edge.Tessellate();
                    m_edgeBufferStorage.VertexBufferCount += xyzs.Count;
                    m_edgeBufferStorage.PrimitiveCount += xyzs.Count - 1;
                    m_edgeBufferStorage.EdgeXYZs.Add(xyzs);
            ProcessEdges(m_edgeBufferStorage);
        // A helper function, analogous to ProcessFaces.
        private void ProcessEdges(RenderingPassBufferStorage bufferStorage)
            List<IList<XYZ>> edges = bufferStorage.EdgeXYZs;
            if (edges.Count == 0)
                return;
            // Edges are encoded as line segment primitives whose vertices contain only position information.
            bufferStorage.FormatBits = VertexFormatBits.Position;
            int edgeVertexBufferSizeInFloats = VertexPosition.GetSizeInFloats() * bufferStorage.VertexBufferCount;
            List<int> numVerticesInEdgesBefore = new List<int>();
            numVerticesInEdgesBefore.Add(0);
            bufferStorage.VertexBuffer = new VertexBuffer(edgeVertexBufferSizeInFloats);
            bufferStorage.VertexBuffer.Map(edgeVertexBufferSizeInFloats);
                VertexStreamPosition vertexStream = bufferStorage.VertexBuffer.GetVertexStreamPosition();
                foreach (IList<XYZ> xyzs in edges)
                    foreach (XYZ vertex in xyzs)
                        vertexStream.AddVertex(new VertexPosition(vertex));
                    numVerticesInEdgesBefore.Add(numVerticesInEdgesBefore.Last() + xyzs.Count);
            bufferStorage.VertexBuffer.Unmap();
            int edgeNumber = 0;
            bufferStorage.IndexBufferCount = bufferStorage.PrimitiveCount * IndexLine.GetSizeInShortInts();
            int indexBufferSizeInShortInts = 1 * bufferStorage.IndexBufferCount;
            bufferStorage.IndexBuffer = new IndexBuffer(indexBufferSizeInShortInts);
            bufferStorage.IndexBuffer.Map(indexBufferSizeInShortInts);
                IndexStreamLine indexStream = bufferStorage.IndexBuffer.GetIndexStreamLine();
                    int startIndex = numVerticesInEdgesBefore[edgeNumber];
                    for (int i = 1; i < xyzs.Count; i++)
                        // Add two indices that define a line segment.
                        indexStream.AddLine(new IndexLine((int)(startIndex + i - 1),
                                                          (int)(startIndex + i)));
                    edgeNumber++;
            bufferStorage.IndexBuffer.Unmap();
            bufferStorage.VertexFormat = new VertexFormat(bufferStorage.FormatBits);
            bufferStorage.EffectInstance = new EffectInstance(bufferStorage.FormatBits);
        public Document Document
            get { return (m_uiDocument != null) ? m_uiDocument.Document : null; }
        private Guid m_guid;
        private Element m_element;
        private List<Line> m_lines;
        private XYZ m_offset;
        private UIDocument m_uiDocument;
        private RenderingPassBufferStorage m_nonTransparentFaceBufferStorage;
        private RenderingPassBufferStorage m_transparentFaceBufferStorage;
        private RenderingPassBufferStorage m_edgeBufferStorage;
        #region Helper classes
        // A class that brings together all the data and rendering parameters that are needed to draw one sequence of primitives (e.g., triangles)
        // with the same format and appearance.
        class RenderingPassBufferStorage
            public RenderingPassBufferStorage(DisplayStyle displayStyle)
                DisplayStyle = displayStyle;
                EdgeXYZs = new List<IList<XYZ>>();
            public bool needsUpdate(DisplayStyle newDisplayStyle)
                if (newDisplayStyle != DisplayStyle)
                    return true;
                if (PrimitiveCount > 0)
                    if (VertexBuffer == null || !VertexBuffer.IsValid() ||
                        IndexBuffer == null || !IndexBuffer.IsValid() ||
                        VertexFormat == null || !VertexFormat.IsValid() ||
                        EffectInstance == null || !EffectInstance.IsValid())
                        return true;
                return false;
            public DisplayStyle DisplayStyle { get; set; }
            public VertexFormatBits FormatBits { get; set; }
            public List<IList<XYZ>> EdgeXYZs { get; set; }
            public int PrimitiveCount { get; set; }
            public int VertexBufferCount { get; set; }
            public int IndexBufferCount { get; set; }
            public VertexBuffer VertexBuffer { get; set; }
            public IndexBuffer IndexBuffer { get; set; }
            public VertexFormat VertexFormat { get; set; }
            public EffectInstance EffectInstance { get; set; }
        #endregion
