Draw an Image
Draw an Image
Draw an Image
Hello can anyone guide me that how can i draw or put a simple image from C# to a particular element in revit model ?
jeremytammik
If you are serious enough to really want this, you can use the analysis visualisation framework AVF.
I did so to display a live webcam image on any selected BIM element:
http://thebuildingcoder.typepad.com/blog/2012/02/revit-webcam-2012.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hello, Actually I am looking for solution in which I can put a image through C# on autodesk model on a particular element and that image should be able to rotate on rotating the model. It should be like augmented reality.
Revitalizer
I don't have a solution at hand, but I can help to specify your question.
You want to implement billboarding, that means placing textured rechtangles always orientated to face the camera.
A behaviour similar to TextNotes placed in a View3D.
Maybe DirectContext3D may be a starting point, but haven't done it myself so far.
I don't think you can create decals via API, and even if you could, it would result in a performance impact if you create dozens of them.
If you could express your billboard information in 3D content instead of 2D images (arrows, text), then you could use the DirectContext for sure.
https://forums.autodesk.com/t5/revit-api-forum/decal-or-familyinstance-to-handle-the-cylindricalface...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hello I tried to use DirectContext3D but could not find the expected result. My aim is to place any random image over the corners of model through some C# code.
Revitalizer
