ContainsPoint Problem!
nam_vt
nam_vt
Hi there!
- I have to use containsPoint(point) to check a point that constaint by a CurveLoop. I had debug and see that true but containsPoint method always return false. Can somebody help me.? this is my source and family I use to check.
 [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class ExportGeometryInfoToCSV : Autodesk.Revit.UI.IExternalCommand
        public object SiteEditingUtils { get; private set; }
        public Autodesk.Revit.UI.Result Execute(
            Autodesk.Revit.UI.ExternalCommandData commandData,
            ref string message,
            Autodesk.Revit.DB.ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uiDoc = uiapp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            Selection choices = uiDoc.Selection;
            // Pick one object from Revit.
            Reference hasPickOne = choices.PickObject(ObjectType.Element);
            if (hasPickOne == null)
                return Result.Succeeded;
            Element element = uiDoc.Document.GetElement(hasPickOne);
            if (element is FamilyInstance)
                double width = 0.0;
                double height = 0.0;
                ElementType type = doc.GetElement(element.GetTypeId()) as ElementType;
                Parameter paramWidth = type.LookupParameter("Width");
                if (paramWidth != null)
                    width = paramWidth.AsDouble();
                Parameter paramHeight = type.LookupParameter("Height");
                if (paramHeight != null)
                    height = paramHeight.AsDouble();
                FamilyInstance familyInstance = element as FamilyInstance;
                Family family = familyInstance.Symbol.Family;
                Document familyDoc = doc.EditFamily(family);
                if (null != familyDoc && familyDoc.IsFamilyDocument == true)
                    using (Transaction trans = new Transaction(familyDoc, "Add Type to Family"))
                        trans.Start();
                        FamilyManager familyManager = familyDoc.FamilyManager;
                        string text = string.Empty;
                        foreach (FamilyParameter familyParam in familyManager.Parameters)
                            text += familyParam.Definition.Name + "\n";
                            if (string.Compare(familyParam.Definition.Name, "Width") == 0)
                                familyManager.Set(familyParam, width);
                            if (string.Compare(familyParam.Definition.Name, "Height") == 0)
                                familyManager.Set(familyParam, height);
                        trans.Commit();
                    FilteredElementCollector collector = new FilteredElementCollector(familyDoc);
                    ICollection<Element> collection = collector.OfClass(typeof(GenericForm)).ToElements();
                    StringBuilder csv = new StringBuilder();
                    foreach (Element elem in collection)
                        if (elem is Extrusion)
                            Extrusion extrusion = elem as Extrusion;
                            if (extrusion.Name == "Void Extrusion")
                                continue;
                            Plane plan = extrusion.Sketch.SketchPlane.GetPlane();
                            CurveArrArray curveArrArray = extrusion.Sketch.Profile;
                            try
                                FindBoun(curveArrArray, doc);
                            catch (System.Exception ex)
                                System.Windows.Forms.MessageBox.Show(ex.Message + "\n" + ex.StackTrace.ToString());
        bool FindBoun(CurveArrArray curveArrArray, Autodesk.Revit.DB.Document doc)
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            collector.OfClass(typeof(FamilySymbol)).OfCategory(BuiltInCategory.OST_Columns);
            List<XYZ> points = new List<XYZ>();
            foreach (CurveArray curveArr in curveArrArray)
                foreach (Curve curve in curveArr)
                    XYZ startpoint = curve.GetEndPoint(0);
                    points.Add(startpoint);
                List<Curve> curves = new List<Curve>();
                    curves.Add(curve);
                using (Transaction acTrans = new Transaction(doc, "TempSkecth"))
                    acTrans.Start();
                    TopographySurface topography = TopographySurface.Create(doc, points);
                    CurveLoop curveLoop = CurveLoop.Create(curves);
                    List<CurveLoop> curveLoops = new List<CurveLoop>();
                    curveLoops.Add(curveLoop);
                    XYZ origin = new XYZ(0,0,0);
                    SiteSubRegion region = SiteSubRegion.Create(doc, curveLoops, topography.Id);
                    if (true == region.TopographySurface.ContainsPoint(origin))
                        System.Windows.Forms.MessageBox.Show("in");
                    else
                        System.Windows.Forms.MessageBox.Show("out");
                    acTrans.Commit();
            return true;
jeremytammik
Dear Nam,
Thank you for your query.
`ContainsPoint` tells you whether the given point 'exists in the topography surface':
http://www.revitapidocs.com/2018.1/d0e5a2f0-eb77-4efb-91f2-ce5428b53ab1.htm
That presumably means that the point is one of the topography surface defining points.
It sounds to me as if you are looking for a different kind of containment, e.g., whether the given point lies inside the extents of the topography surface.
That is a different thing entirely.
I do not believe that the topography surface offers this functionality.
You will probably be better off implementing it yourself, for instance by making use of a simple point in polygon algorithm or 2D Boolean operation library:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
