Door/Window Areas
Door/Window Areas
PhillipM
Message 1 of 30
Door/Window Areas
PhillipM
HI guys.
I'm needing to know the cut area's of windows and doors in a wall. I thought this would be a simple matter of grabbing the BIP "HOST_Area_Computed" as with my testing that was returning the correct area.  It turns out that this is not the case from further testing.
PLease refer to the attached RVT file with two doors inserted into a wall.  They look similar but one is reporting through Revit Lookup 4m2 and the other 2m2.
Why is this?  What actually is "HOST_Area_Computed" reporting?  and what is the most reliable way of getting the cut area of windows and doors?
Regards
Phillip Miller
Replies (29)
Message 21 of 30
office
jeremy, thanks for your reply!
my solution went like:
for i in openingIds:
				try:
					bounding, orient = I.ExporterIFCUtils.GetInstanceCutoutFromWall(doc, element, doc.GetElement(i),)
					print "success"
				except:
					print (" failed for wall %s and opening %s" %(element.Id, i))
cheers peter
Message 22 of 30
jeremytammik
Dear Peter,
Thank you for sharing that.
I summarised your solution on The Building Coder, and also point out a generic link with a similar answer:
http://thebuildingcoder.typepad.com/blog/2016/07/retrieving-a-c-out-argument-value-in-python.html#2
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 23 of 30
Hi Peter,
I am trying to implement your solution in a Dynamo Python node but it fails with "AttributeError: attribute 'ExporterIFCUtils' of 'namespace#' object is read-only" which I think means I am not using the reference to IFCUtils properly... but I am not sure of that.
Can you show how you import Autodesk.Revit.DB.IFC to use it with python?
Also, are you coding for Dynamo or using the revit python shell within Revit?
Message 24 of 30
office
for the import:
from Autodesk.Revit.DB.IFC import *
I = Autodesk.Revit.DB.IFC
and later:
doc =  __revit__.ActiveUIDocument.Document
#element = wall element collected with filter
orient = element.Orientation
best peter
Message 25 of 30
Thanks for the quick response, Peter.
I cannot make it work at all. whenever I assign "I":
Revit Python shell crashes. Have tried with Macros and same result...
I must be missing something somewhere but am clueless now... But If I can't get past loading IFC to use IFCUtils I don't see how to make it work.
Thanks again!
Ivan
Message 26 of 30
office
import clr
import math
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
clr.AddReference('REVITAPIIFC')
from Autodesk.Revit.DB import *
import Autodesk
from System.Collections.Generic import *
uidoc = __revit__.ActiveUIDocument
app = __revit__.Application
cl = FilteredElementCollector(doc)
elements = cl.OfCategory( BuiltInCategory.OST_Walls ).WhereElementIsNotElementType().ToElements()
t= Transaction(doc,"netground")
t.Start()
for element in elements:
	openingIds=element.FindInserts(True,True,True,True)
	if openingIds.Count >0:
			opening = doc.GetElement(i)
			try:
				bounding, orient = I.ExporterIFCUtils.GetInstanceCutoutFromWall(doc, element, opening,)
				loops = List[CurveLoop]()
				loops.Add(bounding)
				area = I.ExporterIFCUtils.ComputeAreaOfCurveLoops(loops)
				print (area)
			except:
				pass
t.Commit()
this code is working on my side.
i am using pyRevit as python enviroment.
https://github.com/eirannejad/pyRevit
i suppose the problem might be to set the paths for python libraries correctly when in python shell
Message 27 of 30
Solved!. To be able to use IFCUtils from a python node in Dynamo I changed your code like this:
# Import DocumentManager and TransactionManager
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
uidoc = DocumentManager.Instance.CurrentUIApplication
doc = DocumentManager.Instance.CurrentDBDocument
app = uidoc.Application
Now it properly loads the references from the API and it works. This is probably trivial but beeing a rookie took me a bit to figure out.
Thanks for your help Kop!.
Message 28 of 30
BTW, the areas are reported in sq feet... conversion is needed for metric system.
Message 29 of 30
office
To clarify:
1) I am working with the python shell, so no Dynamo specific coding is implemented in the sample.
2) of course all units returned from revit are not metric. conversion will always be necessary for Non US 😉 users.
best peter
Message 30 of 30
office
To clarify:
2) of course all units returned from revit are not metric. conversion will always be necessary for Non US users which is appx. 80% of the revit users as I guess?
best peter
