Macro stopped working
I created this macro for ordering Architecture sheets in Revit 2015. When I first created it there was no errors when i built it, and I was able to use the macro on a project. Now it is no longer working. The error is that 'i' does not exist in the current context. I have used the same structure for another macro for sheets, the only difference is that i am now using .StartsWith() instead of the string equaling a value. Can anyone help?
	using(Transaction trans = new Transaction(doc, "Rename Sheets"))
					FilteredElementCollector sheetView = new  FilteredElementCollector(doc).OfClass(typeof(ViewSheet));
					trans.Start();
					foreach (Element e in sheetView)
						try
							ViewSheet Sheet = e as ViewSheet;
								int i=0;
								i++;
								Parameter paramsheetlist = Sheet.LookupParameter("Sheet Number");
								string sheetOrders = paramsheetlist.AsString();
								if(sheetOrders.StartsWith("AD")){
									i=1;
								}else {
									i=2;}
								Parameter paramArch = Sheet.LookupParameter("Sheet Order");
								paramArch.Set(i);
						catch(Exception)
					trans.Commit();
arnostlobel
Oh, how I wish you did not use tabulators in your code 😉
Somehow you ended up withn an extra curly bracket between the statements i=2 and paramArch.Set(i) . The latter statement is outside of the scope of the i variable.  (by the way, I suggest yo do not name your variables "i"). paramValue woud read a lot nicer.
Arnošt Löbel
