Does 'Selection' contain a definition for 'Elements' ?
These codes are from a book about Revit API(compiled by Autodesk), but VS says that 'Selection' does not contain a definition for 'Elements' and no extension method 'Elements' accepting a first argument of type 'Selection' could be found (are you missing a using directive or an assembly reference?). So what is the problem?  Please help me~
using System;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI;
namespace select
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Class1:IExternalCommand
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,ref string message,ElementSet elements)
            try
                UIDocument uIDocument = revit.Application.ActiveUIDocument;
                Selection selection = uIDocument.Selection;
                ElementSet collection = selection.Elements;
                if (collection.Size == 0)
                    TaskDialog.Show("Revit", "No elements selected");
                else
                    string info = "information:";
                    foreach (ElementId elem in collection)
                        info += "\n\t" + elem.GetType().ToString();
                    TaskDialog.Show("Revit", info);
            catch(Exception e)
                message = e.Message;
                return Autodesk.Revit.UI.Result.Failed;
            return Autodesk.Revit.UI.Result.Succeeded;
aignatovich
Hi!
Use Selection.GetElementIds() instead, this changed few Revit versions ago
so-chong
Thank you all very much!
