I've been working on a script that adds parameters to families listed in a schedule based on a user input of the column name in the schedule (the script is supposed to grab the parameter from the schedule and add it to the family). Then, I realized that the dozen or so hours I've spent pulling out my hair figuring it out could have been avoided, since there already exists something that does this in the UI. However, I'm a little stubborn and still want the script to be worthwhile, so is there any documentation for the following UI button? Thanks in advance!
Yup, it often pays off to explore existing UI functionality before even thinking about addressing the task via API. Still, I asked the development team for you.
You (or maybe Revit) lost me. How can you add a a parameter to a category, and not add it to all the elements in that category?
From the looks of your dialog box, it looks like you are trying to add a "project parameter". But how did you get both "type" and "instance" unchecked at the same time? Doesn't it have to be one or the other?
I can't seem to make any combination of selections that will allow me to uncheck the "Add to all elements in a selected category" box. It remains checked and greyed out no matter what I do or select.
This can happen if you use the same shared parameter in two different families, as a Type in one of them and an Instance in the other, then import both families into the same project.
