Does Catia file will support revit program
Dear Revit Team
Could you help me by reply, I facing diffculty in opening DXML file format in Revit, Basicall the complet model is done in CATIA ,
If it does not.... how can i open it. kindly reply me as earliest.
Regards
Srikanth
jeremytammik
Dear Srikanth,
Do you mean 3DXML?
https://en.wikipedia.org/wiki/3DXML
I am not aware of any support in Revit for 3DXML.
Further, is this a Revit API issue, or an end user question?
Are you doing anything programmatically, or just using the standard Revit user interface?
Otherwise, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
