Document corruptioin with Structural Analysis Toolkit 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having an issue with our Revit AddIn when Structural Analysis Toolkit 2016 is also installed.
On Revit 2016 when Structural Analysis Toolkit 2016 is installed and if a plugin registers for the event Document.DocumentSaveAs then my revit document gets immediately corrupt when it is saved as.
Note that I am not doing anything inside the delegate that listens to the Document.DocumentSaveAs event. Just registering a delegate corrupts the document.
Also not that this only happens in Revit 2016 and the same code works fine in Revit 2015 with Structural Analysis toolkit 2015.
Following is the code snippet:
document.DocumentSavingAs += OnDocumentSavingAs;
private static void OnDocumentSavingAs(object sender, Autodesk.Revit.DB.Events.DocumentSavingAsEventArgs e)
Following are the steps to reproduce:
1) Install Structural Analysis Toolkit 2016 on Revit 2016
2) In your own addin subscribe to the Document.DocumentSaveAs event
3) Make sure your plugin loads into revit as expected.
4) With both your plugin as well as SAT 2016 installed, launch Revit and open an new Architectural Template project.
5) Save the project as MyProject.rvt
6) Close the document. Notice that you would get the dialog to save the document again even though you just saved it.
7) Try to open the project again. Notice the message saying "Data in file MyProject.rvt is corrupt and needs to be manually recovered."
Could somebody from Autodesk please confirm this issue and suggest a fix / workaround ?
Thanks !!
