Document.AutoJoinElements
AdvancedBIMSystems
AdvancedBIMSystems
I'm looking for a solution to automatically join multiple neighboring families (non-system) of the same type.
I'm not sure how to implement doc.AutoJoinElements() as I can't find any examples online at all.
From what I can tell JoinGeometryUtils only works on joining two different system family types such as walls / columns / floors (but I'm happy to be wrong about this 🙂
Thanks in advance
jeremytammik
Afaik, AutoJoinElements is always called automatically every time you commit a transaction. A decade ago, there was use in calling it manually. It might still be useful to regenerate the model midd-transaction. To use it explicitly, just invoke it as is:
  doc.AutoJoinElement();
By the way, have you ever taken a peek at the documentation? It says the same thing:
Forces the elements in the Revit document to automatically join to their neighbors where appropriate.
Syntax
C#
public void AutoJoinElements()
Visual Basic
Public Sub AutoJoinElements
Visual C++
public:
Remarks
Use this method to force elements in the document to automatically join to their neighbors. Note that when a transaction is committed there is an automatic call to automatically join elements.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
AdvancedBIMSystems
Thanks for the quick reply Jeremy, much appreciated.
I have multiple adjacent instances of a generic model family which contains a nested shared generic model. I can easily manually join the shared nested components in Revit with the Join Geometry tool by mousing over & pressing the Tab key to select etc. but I'm trying to automate this task via the api.
I've tried JoinGeometryUtils as follows in a (futile) attempt to join the same family to it's neighbors :
using (Transaction tx = new Transaction(doc, "Autojoin"))
   tx.Start();
   foreach (FamilyInstance box in family)
    if (!JoinGeometryUtils.AreElementsJoined(doc, box, box))
        JoinGeometryUtils.JoinGeometry(doc, box, box);
tx.Commit();
I've applied a single FilteredElementCollector prior to the transaction to grab the families.
JoinGeometryUtils wants to join element A to element B but can they be the same element type?
(p.s. my C# is little blunt)
jeremytammik
Analyse the model in detail to discover exactly what changes were caused by your successful manual joining operation and how they are reflected via the API-accessible properties and relationships:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
The API provides several different joining operations and options. Search for 'join' and see for yourself. Maybe this other option will suit your needs:
Jeremy Tammik
The Building Coder
maciekglowka
you can join two elements of the same type, a floor with a floor for example, using this API method.
Do you get any error/warning message?
Maybe you can wrap your code into try / catch and see what exception is thrown.
If you need some sample code for auto-joining elements, take a look here. It is a node library for Dynamo, but I am writing in C# and Revit API is the same:
https://github.com/maciekglowka/Onion/blob/master/Onion/AutoJoin.cs
AdvancedBIMSystems
Thanks for the link, very much appreciated 🙂
I'll pick through the code & see if anything sticks, it looks promising.
I'll post the solution if I can get something working.
All the best.
