Dockable Pane Button Close Event?
Is there an event that I can subscribe to to be notified when a user clicks on the black "X" to close a dockable pane?
I could setup a timer to check using.
Dim pane As DockablePane = shareduiApp.GetDockablePane(docPaneID)
Dim isShown As Boolean = pane.IsShown()
But that doesn't seam very efficient.
Any other ideas?
Regards
Phillip
I guess you've tried searching for OnClosing or Closed events ?
GonçaloFeio1321
Does UIControlledApplication.DockableFrameVisibilityChanged help?
I'm using a xml Page as the DockablePaneProviderData FrameworkElementand that doesn't have those events.  Also when you click on the cross or close a dialog I'm pretty sure that all it is doing is hiding the control.  So I tried the isVizabileChanged event on the page but that doesn't fire either. 😞
BINGO.
You nailed it.  That does work and is exactly what I require.
Thanks for the help.
Regards
Phillip
