do something when a command is active
Joris.vd.Meulen
Joris.vd.Meulen
Is there an option in api that allows us to do something when another command is active?
For instance:
I click on wall command and like to manually override the first pickpoint with my command/script.
That script of mine returns a calculated point, but this script can't be launched / button is greyed out.
Am I right to state that this behaviour (run script while other command is active) is not possible?
(Right click, snap overrides is possible, that behaviour can be mimicked?)
love python coding
jeremytammik
I don't know whether it is completely impossible; almost nothing is. It is probably extremely tricky, in any case, due to the single threaded nature of Revit and the restriction of the API to a valid API context, also running in the single thread.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Sean_Page
You could look at Command Binding, but if you already know one point because it's calculated, then why not just create a command that has the user pick the end point and then create the wall programmatically?
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Joris.vd.Meulen
@Sean_Page because I'd like to create a multipurpose command, so it's not related to one command.
My simple scripts
asks for a base point
asks for two points
returns the midpoint of two user given points.
I'd like to use this script as I'm creating a wall, as I'm copying a piece of furniture, as I'm moving a curtain wall.
(at the moment I run this script based upon a selection, but that is an extra step)
But as @jeremytammik mentioned, I too stumbled upon some limitations. Perhaps I'm wrong?
love python coding
