Disable Warning Messages/Popups from REVIT 2016
I want to disable/remove the warning and popup messages coming while opening the REVIT Project in REVIT 2016. I have attached the two messages coming in my way. Also, I don't want any suggestion boxes from the REVIT.
Please help me on this ASAP
aignatovich
Hi!
Look at http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32 especially Failure API section
Hi
Can you please give me specific link or code to disable this boxes.
Is there any setting in the REVIT software which can be turned off for this boxes?
aignatovich
You can swallow all warning messages, see http://thebuildingcoder.typepad.com/blog/2016/09/warning-swallower-and-roomedit3d-viewer-extension.h...
For the dialog in the first picture you should perform a check with debugger, create event handler for DialogBoxShowing event, if it is not helpful, you can use system WindowsAPI, something like at http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
