Direct Modification of KeynoteTable
Is there a way to directly change KeynoteEntrys in a KeynoteTable?  I am looking to add to it by creating a new KeynoteEntry, as well as remove entries from it.  Is this possible?  Or is the only way to build up a ne keynote.txt file and load it into the Revit file?
Mustafa.Salaheldin
Use the KeynoteTable.DeleteEntity() Method and KeynoteEntry constructor method  to do the job.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Thank you Mustafa. I saw the KeynoteEntry Constructor, but didn't realize that the constructor added it directly to the table.  Thank you for clarifying this.
Mustafa.Salaheldin
Don't bother. At your service always.
¯\_(ツ)_/¯
Mustafa Salaheldin
I am struggling to actually delete a key from the keytable. I am unable to get the schema needed. When I use the method GetEntitySchemaGuids on the KeyTable, the count on the list of guids returned is 0. The list of keys in the table is over 500. What am I missing to get the schema
Mustafa.Salaheldin
Please provide me with sample of your code so I can help.
¯\_(ツ)_/¯
Mustafa Salaheldin
Thanks.  I am just using the revit addin template. This is in Command.cs
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            var keyTable = KeynoteTable.GetKeynoteTable(doc);
            var keys = keyTable.GetKeyBasedTreeEntries();
            var entity = keys.FindEntry("3");
            var schema = keyTable.GetEntitySchemaGuids();
            //var delete = keyTable.DeleteEntity();
            return Result.Succeeded;
