Dimensioning problems with stud walls
We like to dimension to face of stud. When we change our wall type to show the gyp. wrapping the stud, it no longer allows us to select the end point of the stud (red point in attached image). Any solution besides faking it with a reference line?
jeremytammik
Dear Leia,
Thank you for your query.
However, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
