Dimension on Hatch Pattern Slab
Message 1 of 35
Hi everyone,
I want to get dimension on hatch pattern slab like this. But I don't know how to retrieve hatch line.
Please help, thanks :).
Replies (34)
Message 21 of 35
c_hanschen
@FAIR59 , Thanks for this! I think you helped a lot of people a lot wit this reply.
Should it also be possible to get the hatchlines through Custom Exporter?
I gave it a try, but got no further accessing Face (OnFaceBegin) and Polymesh (OnPolymesh)
I would think that the Custom Exporter can access the (Hatch)Lines? How else would you be able to export patters?
Thanks in advance,
Chris
LKSVDD architecten
The Netherlands
Message 22 of 35
RPTHOMAS108
They are there part of OnPolylineSegments.
Each call is one line for the square grids model hatch pattern e.g.
OnPolylineSegments =============================================
IsFilled=False
Line Properties:
RGB=0,0,0
LineWidth=0.000328083988279104,Transparency=0
Id:-1 PatternId
GetVertices
XYZ:-80.306982018425,23.9686043593474,0
XYZ:-58.1716084357853,23.9686043593474,0
IsFilled=False
Line Properties:
RGB=0,0,0
Id:-1 PatternId
GetVertices
XYZ:-58.1716084357853,47.2261081288202,0
Message 23 of 35
c_hanschen
@RPTHOMAS108 , Thanks for your Reply!
I can't get 'OnPolylineSegments' to be invoked, can't even get the 2D view (ceilingplan) exported.
Maybe you can take a look at my new post?
https://forums.autodesk.com/t5/revit-api-forum/custom-exporter-the-view-is-not-exportable-but-ceilin...
Thanks in advance,
Chris Hanschen
LKSVDD architecten
The Netherlands
Message 24 of 35
c_hanschen
@BardiaJahan ,
You sad:
"But I'm trying to figure out how to get XYZ coordinates of the grid line"
Did you succeeded? Without creating a dimension first?
I'm trying to get all start- and endpoints of the hatch-lines, got it working for ceilings by exporting a CeilingPlan trough Custom Exporter, but now i'm trying to get the hatchlines of walls.
I got all the reference of the hatchlines thanks to previous post of @FAIR59 on https://forums.autodesk.com/t5/revit-api-forum/dimension-on-hatch-pattern-slab/m-p/7078368#M22785
Thanks in advance,
Chris Hanschen
The Netherlands
Message 25 of 35
c_hanschen
How can you know if the Reference is outside the Face?
The reference is created anyway, even the dimension outside the face.
the only check in this code is ==Null, but that does not check if the reference is inside the face.
Thanks in Advance,
Chris
The Netherlands
Message 26 of 35
cdd1171022
Hi, refer to your code and how should I label multiple
Message 27 of 35
Chuong.Ho
Recenlly, I'm tried find the pick first point intersect of pattern and then suscess, but when you change between Floor and Ceiling, you need to change the number step of pattern:
Floor :
int index = 2 + (ip * _gridCount * 2);
int index = 3 + (ip * _gridCount * 2);
Ceiling :
int index = 1 + (ip * _gridCount * 2);
Example to find the first intersect of pattern :
public XYZ? FindPlacePointPattern()
        using Autodesk.Revit.DB.Transaction tran = new Transaction(Doc, "Find Place Point Pattern");
        tran.Start();
        //check for model surfacepattern
        var hostObject = this.HostObjectPart.HostObject;
        Reference? top = HostObjectUtils.GetTopFaces(hostObject)
            .FirstOrDefault();
        PlanarFace? topFace = hostObject.GetGeometryObjectFromReference(
            top) as PlanarFace;
        Material mat = Doc.GetElement(
            topFace.MaterialElementId) as Material;
        ElementId foregroundPatternId = mat.SurfaceForegroundPatternId;
        FillPatternElement? patterntype = Doc.GetElement(
            foregroundPatternId) as FillPatternElement;
        FillPattern pattern = patterntype.GetFillPattern();
        if (pattern.IsSolidFill || pattern.Target == FillPatternTarget.Drafting) return null;
        // get number of gridLines in pattern
        int _gridCount = pattern.GridCount;
        //https://forums.autodesk.com/t5/revit-api-forum/dimension-on-hatch-pattern-slab/m-p/7078368#M22785
        // construct StableRepresentations and find the Reference to HatchLines
        string StableRef = top.ConvertToStableRepresentation(Doc);
        ReferenceArray _resArr = new ReferenceArray();
        for (int ip = 0; ip < 2; ip++)
            string StableHatchString = StableRef + $"/{index}";
            var HatchRef = Reference.ParseFromStableRepresentation(Doc, StableHatchString);
            _resArr.Append(HatchRef);
        // 2 or moreReferences => create dimension
        Dimension d1 = null;
        if (_resArr.Size > 1)
            d1 = Doc.Create.NewDimension(Doc.ActiveView,
                Line.CreateBound(XYZ.Zero, new XYZ(1, 0, 0)), _resArr);
            // move dimension a tiny amount to orient the dimension perpendicular to the hatchlines
            // I can't say why it works, but it does.
            ElementTransformUtils.MoveElement(Doc, d1.Id, new XYZ(.01, 0, 0));
        _resArr.Clear();
        // 2 or more References => create dimension
        Dimension? d2 = null;
            d2 = Doc.Create.NewDimension(Doc.ActiveView,
                Line.CreateBound(XYZ.Zero, new XYZ(0, 1, 0)), _resArr);
            ElementTransformUtils.MoveElement(Doc, d2.Id, new XYZ(0, .01, 0));
        // create dimension between two dimensions
        // try get cross point of two dimensions
        if (d1 != null && d2 != null)
            XYZ? intersection = FindIntersectByTwoDirection(d1, d2);
            return intersection;
        tran.RollBack();
        return null;
Chuong Ho
Message 28 of 35
jorge_morente
Many thanks to @Chuong.Ho  and especially to @FAIR59  for this very valuable information. I have used this code and it works perfectly for me. I managed to center elements in the ceiling grid when I have the ceiling and the element in the same model. What happens when the ceiling is in a linked model? I tried it and I have a problem.
What I do to get a point from the grid and from there 2 perpendicular lines is to get the origin of each dimension, add or subtract half the value of one of the grid cells, and I have the point positioned on the line. I create a line with the point and direction, and I have "the axes" of the grid. This worked perfectly in my initial case but not with the ceiling in a linked model.
As seen in the images, I have the 2 dimensions from which I can obtain any of the green lines and thus any of the 4 red points. But the point I get with the script is the origin of the pink lines. It is displaced and I don't know why.
At first, I thought it could be because the origin point of the linked model was offset, but no, I checked and it is at (0,0,0). I can't figure out what it could be. Any ideas???
Message 29 of 35
jorge_morente
UPDATE 1: In the previous example, I had ceilings in both the model and the linked model, and it seems I was mixing things up that I shouldn't have.
I've created a model from scratch where I only have one ceiling, and it's from a linked model, and I've detected the problem. The references we created by adding some indices at the end to create the dimensions are not valid because the references I need are of the type:
33899bce-a21c-4067-af38-2260a13fa4e9-00023f0b:0:RVTLINK:147216:1/181
The string StableRef = bottom.ConvertToStableRepresentation(linkedDocument); command is giving me the following value:
f6c5042c-3953-4e47-afb0-42e0e62b1e73-00023f10:1:SURFACE
Curiously, if I dimension the grid in the model where the ceiling is, the references are with the code f6c5042... which is the UniqueId of the ceiling. If I dimension it in the model with the linked ceiling, the dimension references are 33899bce.... It's as if Revit renames the references, and I have no way of obtaining them from the ceiling because they are not those.
Any ideas?
Message 30 of 35
FAIR59
Message 31 of 35
jorge_morente
Thank you very much for your answer. I have tried to create the reference with your info and, following the same code as your example, I've managed to get:
8a9264c9-8bf7-47e4-9298-b2cb9c61c780-00037ae4:0:RVTLINK:228068:0/8.
It is not exactly the code I need because I should get 00037b5a but I have 00037ae4 which is part of the code above. Why?
Message 32 of 35
c_hanschen
RevitLinkInstance vs. Document?
Message 33 of 35
jorge_morente
Hi @c_hanschen !
I don't know which element will be 00037ae4 but now I know which one is 00037b5a. It' the RevitLinkInstance UniqueID.
Thank you!!!
Message 34 of 35
jorge_morente
I’m sharing the complete code I've used in case anyone got lost with all the posts. The code works perfectly for simple patterns, both in the model and in links:
int gridCount = pattern.GridCount;
for (int i = 1; i < 3; i++)
    int index = i + (ip * gridCount *2);
    string StableHatchString = null;
    if (isLinked)
      var uniqueId = revitLinkInstance.UniqueId;
      string indexSurface = StableRef.Length >= 10 ?
      StableRef.Substring(StableRef.Length - 10) : StableRef;
      StableHatchString = $"{uniqueId}:0:RVTLINK:{ceilingInstance.Id}
                         {indexSurface}/{index}";
    else
    Reference HatchRef = null;
    HatchRef = Reference.ParseFromStableRepresentation(document,
               StableHatchString);
    if (HatchRef == null)
      continue;
  Dimension dimension = null;
    dimension = document.Create.NewDimension(document.ActiveView,
    ElementTransformUtils.MoveElement(document, dimension.Id,
  dimensions.Add(dimension);
  _resArr.Clear();
Just to add that I tested it with a ceiling that has a more complex pattern, with a gridCount of 6, 2 horizontally and 4 vertically, and I had to change the index formula because it was giving me the same dimension:
int index = i + 2 + (ip * gridCount * 2);
It worked for me, but I'm not sure if it will work in other cases where the gridCount is not equal to 2. This is the pattern. I managed to place the element in the center of the pattern, represented by the yellow dot. The goal was to place it at one of the intersections of the green lines. I think it's very complicated when the patterns aren't simple, and it's not worth the effort.
Thanks to everyone who helped solve this problem.
Message 35 of 35
jeremy_tammik
Thank you all for the useful updates and enhancements to this solution. I shared them on the blog for posterity:
