Dimension arc length in Revit API
pasgatto
pasgatto
Hi to all,
I tried to search API documentation, this forum, web etc.. While i've not problem with linear dimensions  i didnt find anything about dimensioning arc length (i'm using C# language) in project environment.
I'd like to dimension arc detail lines in the current project view.
I tried the  NewArcLengthDimension Method (View, Arc, Reference, Reference, Reference)  as reported in API documentation:
https://www.revitapidocs.com/2015/a33279db-ba00-7cb7-1cea-9f4eac33b747.htm
but it seems to work only in the family editor, not in project environment ..
Perhaps is not possible to do by API?
Thank you to anybody will help me
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @pasgatto ,
Looks like it is not possible to create ArcLength Dimension in project document using Revit API.
https://forums.autodesk.com/t5/revit-ideas/api-create-arc-length-and-radial-dimensions/idi-p/7003021
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremy_tammik
Discussed in more depth here (internal slack discussion):
https://forums.autodesk.com/t5/revit-api-forum/diameter-dimensions-with-revit-api/m-p/9209398
Please refer to that thread and always search for existing questions and answers before raising new ones.
pasgatto
Hi @naveen.kumar.t
Thank you for your answer!
This is what I was afraid of..  :-(...
pasgatto
Hi @jeremy_tammik
Thank you for the links!
Anyway i already saw these posts but were talking about angular, radial dimension etc... I didnt find anything about arc length dimension...
jeremy_tammik
Please add your comments, use case, business requirements and vote to the wish list request in the Revit Idea Station:
