Diameter Dimensions for Sweep Profile
Mustafa.Salaheldin
Advisor Advisor
Message 1 of 15
Mustafa.Salaheldin
Hello
I have created a sweep using a circle profile and a path. Now I need to add a Diameter Dimension to the arc inside the profile. Any thoughts?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Replies (14)
Message 2 of 15
jeremy_tammik
Is this inside a family definition, or where? Have you researched how to achieve the desired result manually in the UI? What are the exact steps to achieve that?
Message 3 of 15
Mustafa.Salaheldin
Hello @jeremy_tammik
Yes, I'm trying this in Family Editor, here is my code:
IList<ElementId> elementIds = sweep.ProfileSketch.GetAllElements();
foreach (ElementId elemid in elementIds)
    Element element = family.GetElement(elemid);
    if (element is ModelArc marc)
        if (marc.GeometryCurve is Arc arc)
            FilteredElementCollector views = new FilteredElementCollector(family).OfCategory(BuiltInCategory.OST_Views).OfClass(typeof(View3D));
            View3D v = views.FirstOrDefault(v => v.Name == "{3D}") as View3D;
            Reference arcRef = arc.Reference;
            XYZ origin = arc.Center;
            family.FamilyCreate.NewDiameterDimension(v, arcRef, origin);
And it is achievable by UI, edit any Conduit Fitting Family that is created using a sweep. Edit the sweep -> Edit the Profile -> Put Diameter Dimension on the Profile curves.
My problem is with line 13 it throws error:
Please advise 😃
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 4 of 15
ctm_mka
my guess based on your code would be the view, try any 3d view that isn't the default {3D}. If that isn't it then i suspect it doesn't it like 3D views at all.
Message 5 of 15
Mustafa.Salaheldin
@ctm_mka No mate the 3D view has nothing to do with this. I suspect the "Origin" parameter, seems like it needs to be something else.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 6 of 15
Mustafa.Salaheldin
One quick point that is worth to mention is adding the diameter dimension is only allowed in sketch edit mode of the profile. Not sure if this is the cause, but let us see what it could be!
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 7 of 15
Mustafa.Salaheldin
Another quick note: when using Lookup to investigate the diameter dimension I created manually it shows the same "arcRef" and "origin" I set. The difference is "view" shows null and instead arcRef it shows references.
Note: I used the dimension ID to search for the element in Lookup 😄
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 15
Mustafa.Salaheldin
@jeremy_tammik can you please advise?
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 9 of 15
Mustafa.Salaheldin
@naveen.kumar.t would you please check with the development team if this is not a bug in Revit 2022.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 10 of 15
ctm_mka
@Mustafa.Salaheldincurious, if you manually edit the sketch of the profile, and snoop active view, what does it return?
Message 11 of 15
Mustafa.Salaheldin
@ctm_mka This is impossible, during edit mode Lookup is deactivated
The only way is as I showed you before, get the id of the curve or the dimension, use it outside the sweep/profile edit in mode Lookup to get to the dimension.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 12 of 15
Mustafa.Salaheldin
I need to know if this is a bug in the API or this method is not supported in sketch mode.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 13 of 15
jeremy_tammik
Dear Mustafa,
Sorry for not jumping in sooner. I am on leave and therefore trying to remain completely inactive here. I'm afraid I am not completely succeeding...
I asked the development team for you.
Cheers
Jeremy
Message 14 of 15
Mustafa.Salaheldin
@jeremy_tammik appreciated and enjoy your vacation. 🖖
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 15 of 15
studio-a-int
We ran into a similar issue, and we gave up after few tries. In Revit 2023/2024 in Families trying to add a Diameter Dimension to a Model Line fails with the same error as yours. We did not have time to investigate too much, but it is simple to replicate:
In a Family, create a SketchPlane where the curve is.
Create an arc from a curve.
Create a ModelCurve from the arc in the SketchPlane.
Try to create NewDiameterDimension to the ModelCurve -> it fails with the same error message.
Error
Error: One of the conditions for the inputs was not satisfied. Consult the documentation for requirements for each argument.
OK
