Determining useable parameters - ParameterFilterElement
kevin_fielding
kevin_fielding
Good morning all,
I'm looking for someone to steer me in the right direction if possible
When creating view filters via the dialog box, not all parameters are available to the users. I want to create filters programmatically, is there a way to determine through the api which parameters are useable by the ParameterFilterElement so I can present a list to the end user similar to that within the dialog box?
The only method I can think of is creating a filter and using the AllRuleParaemtersApplicable method, however this seems particularly inefficient.
Thanks in advance,
Kevin
kevin_fielding
I've found the ParameterFilterUtilities class contains the method GetFilterableParametersInCommon,
Hopefully this will suit my needs.
K
