Deleting Shared Parameters
slyons1234
Observer Observer
slyons1234
Observer
Observer
I am trying to clean up our office project template. There are some previously made door parameters that I no longer need. I was able to delete some of the parameters through the "project parameters" tab. However, there are some shared parameters that I cannot delete. These are not parameters in the door family. I cannot find their original shared parameter txt file because they were created by other team members over the past years. How can I delete these shared instance parameters?
JimJia
Dear Sarah,
Please accept our sincerer apology for the delay! We had a backlog in the queue these days.
I think this blog can give you some help if you can use API to your request.
http://thebuildingcoder.typepad.com/blog/2009/08/deleting-a-shared-parameter.html
If you want to delete the parameter in UI. Maybe you can post your question here: https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
Thank for your understanding and cooperation.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Dale.Bartlett
I might be misreading the question, but it is worth noting that to the best of my knowledge, it is still impossible to truly purge Shared Parameters from a project (from a family, yes) database. The GUID remains, along with its link to its original name.
And whether this helps, you can export "orphaned" Shared Parameters into a new Shared Parameter file.
Dale
______________
Yes, I'm Satoshi.
FAIR59
Since we have access to the SharedParameterElement's in a document, you can remove a shared parameter from the document, by deleting the SharedParameterElement that belongs to the shared parameter.
(for finding the SharedParameterElement see my reply https://forums.autodesk.com/t5/revit-api-forum/filter-with-shared-parameter-guid-id/m-p/7127726#M231...)
NOTE OF CAUTION:
You can do this at your own peril, since Revit will delete the parameter even if it's used in families and/or ParameterBindings with NO warning. If the parameter was used in a formula in the family, the formula is deleted, even further degrading the family.
So verify yourself that the parameter is not being used in any way.
            Guid myGuid = new Guid("1941bdda-f6f3-4908-a1f2-25d0f968cb02");  // GUID of shared parameter
            SharedParameterElement sParamElement = SharedParameterElement.Lookup(document, myGuid);
            using (Transaction t = new Transaction(document, "remove sharedParameter"))
                t.Start();
                document.Delete(sParamElement.Id);
                t.Commit();
