Deleting levels using WindowsForm
Hello all,
I am trying to write an add-in that brings up a WindowsForm that has a list of check boxes that the user can select to determine which levels (and reference planes) they want to be removed from the project. I have created an ArrayList with the Element Ids for both the levels and planes. It is listed below as ArrayList.cs. I have also listed my the class I am trying to use to delete the elements. It is labeled BasementDeleteElements.cs. I am struggling with getting the asementDeleteElements.cs to access the array and then to use the variables in the array as the Element Ids for Revit to delete. I am very new to C# and would appreciate all the help I can get.
ArrayList.cs
using System;
using System.Collections;
using System.Collections.Generic;
class ArrayListLevels
    // Main Method
    public static void Main(String[] args)
        #region Basment
        // create basement array list
        ArrayList BasementList = new ArrayList();
        // add elements to array list
        BasementList.Add("1600991");
        BasementList.Add("1601000");
        BasementList.Add("1600999");
        BasementList.Add("1600996");
        BasementList.Add("1600997");
        BasementList.Add("1600998");
        #endregion
        #region Level one
        // create level one array list
        ArrayList OneList = new ArrayList();
        OneList.Add("1460");
        OneList.Add("1363089");
        OneList.Add("1534822");
        OneList.Add("1363104");
        OneList.Add("1362898");
        OneList.Add("1363074");
        #endregion
        #region Level Two
        // create level two array list
        ArrayList TwoList = new ArrayList();
        TwoList.Add("1287144");
        TwoList.Add("1363704");
        TwoList.Add("1534823");
        TwoList.Add("1363719");
        TwoList.Add("1363560");
        TwoList.Add("1363689");
        #endregion
        #region Level Three
        // create level three array list
        ArrayList ThreeList = new ArrayList();
        ThreeList.Add("1287185");
        ThreeList.Add("1364100");
        ThreeList.Add("1534824");
        ThreeList.Add("1364115");
        ThreeList.Add("1363988");
        ThreeList.Add("1364085");
        #endregion
        #region Level Four
        // create level four array list
       ArrayList FourList = new ArrayList();
        FourList.Add("1287204");
        FourList.Add("1671040");
        FourList.Add("1671042");
        FourList.Add("1671041");
        FourList.Add("1364404");
        FourList.Add("1671039");
        #endregion
        #region Level Five
        // create level five array list
       ArrayList FiveList = new ArrayList();
        FiveList.Add("1287223");
        FiveList.Add("1671045");
        FiveList.Add("1671047");
        FiveList.Add("1671046");
        FiveList.Add("1364499");
        FiveList.Add("1671044");
        #endregion
        #region Level Six
        // create level six array list
        ArrayList SixList = new ArrayList();
        SixList.Add("1287241");
        SixList.Add("1671050");
        SixList.Add("1671052");
        SixList.Add("1671051");
        SixList.Add("1364600");
        SixList.Add("1671049");
        #endregion
        #region Level Seven
        // create level seven array list
       ArrayList SevenList = new ArrayList();
        SevenList.Add("1287259");
        SevenList.Add("1671055");
        SevenList.Add("1671057");
        SevenList.Add("1671056");
        SevenList.Add("1364732");
        SevenList.Add("1671054");
        #endregion
        #region Level Eight
        // create level eight array list
       ArrayList EightList = new ArrayList();
        EightList.Add("1287278");
        EightList.Add("1671060");
        EightList.Add("1671062");
        EightList.Add("1671061");
        EightList.Add("1364825");
        EightList.Add("1671059");
        #endregion
        #region Roof
        // create roof array list
        ArrayList RooftList = new ArrayList();
        RooftList.Add("62406");
        #endregion
#region Namespaces
using System;
using System.Linq;
using Autodesk.Revit.DB;
#endregion
namespace LevelDeleteForm
    #region Basement Level
    class BasementDeleteElements
            public void DeleteElement(Document doc)
            Element element = FindElementByName(doc, typeof(Level), "1600991");
            using (Transaction t = new Transaction(doc, "Delete element"))
                t.Start();
                doc.Delete(element.Id);
                t.Commit();
        public void DeleteElements(Document doc)
            List<Level> levels = GetLevels(doc);
            List<ElementId> idSelection = new List<ElementId>();
            foreach (Level l in levels)
                Element e = l as Element;
                idSelection.Add(e.Id);
                t.Start();
                doc.Delete(idSelection);
                t.Commit();
        public List<Level> GetLevels(Document doc)
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            ICollection<Element> Levels = collector.OfClass(typeof(Level)).ToElements();
            List<Level> List_Levels = new List<Level>();
            foreach (Level l in Levels)
                List_Levels.Add(l);
            return List_Levels;
        public Element FindElementByName(Document doc, Type targetType, string targetName)
            return new FilteredElementCollector(doc).OfClass(targetType).FirstOrDefault<Element>(e => e.Name.Equals(targetName));
    #endregion
jeremytammik
