Delete Views, Remove Linked Files from Revit File
dwightduronidavy
dwightduronidavy
Dear all,
I have created the below application module macro to undertake the following tasks:
delete all views; legends; schedules (except with suffix "_!")
remove all linked files (including instances)
However, the revision history gets deleted from Landing Sheet (which should be retained)
and CAD Formats unable to be removed.
Any help would be very much appreciated.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using System.Collections.Generic;
using System.Linq;
namespace DDA_CSharpModule1
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("EB0917F2-8040-4F52-9F49-945C816A26E4")]
    public partial class ThisApplication
        private void Module_Startup(object sender, EventArgs e)
        private void Module_Shutdown(object sender, EventArgs e)
        #region Revit Macros generated code
        private void InternalStartup()
            this.Startup += new System.EventHandler(Module_Startup);
            this.Shutdown += new System.EventHandler(Module_Shutdown);
        #endregion
        public void DeleteViewsSheetsRemoveLinks()
            UIApplication uiApp = new UIApplication(this.Application);
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            using (Transaction transaction = new Transaction(doc, "Delete Views, Schedules, and Links"))
                try
                    transaction.Start();
                    // Filter views to delete
                    List<View> viewsToDelete = new FilteredElementCollector(doc)
                        .OfClass(typeof(View))
                        .Cast<View>()
                        .Where(view => view.IsValidObject && !view.IsTemplate && !view.Name.EndsWith("_!") &&
                                       (view.ViewType == ViewType.FloorPlan ||
                                        view.ViewType == ViewType.Section ||
                                        view.ViewType == ViewType.ThreeD ||
                                        view.ViewType == ViewType.DraftingView ||
                                        view.ViewType == ViewType.Legend ||
                                        view.ViewType == ViewType.Elevation ||
                                        view.ViewType == ViewType.Schedule))
                        .ToList();
                    foreach (View view in viewsToDelete)
                        if (view.IsValidObject)
                            try
                                doc.Delete(view.Id);
                            catch (Exception ex)
                                TaskDialog.Show("Error""Failed to delete view: " + view.Name + " due to: " + ex.Message);
                    // Filter schedules to retain Revision Codes and Issue Dates
                    List<ViewSchedule> schedulesToDelete = new FilteredElementCollector(doc)
                        .OfClass(typeof(ViewSchedule))
                        .Cast<ViewSchedule>()
                        .Where(schedule => schedule.IsValidObject &&
                                           !schedule.Name.Contains("Revision") &&
                                           !schedule.Name.Contains("Issue Date"))
                        .ToList();
                    foreach (ViewSchedule schedule in schedulesToDelete)
                        if (schedule.IsValidObject)
                            try
                                doc.Delete(schedule.Id);
                                TaskDialog.Show("Error""Failed to delete schedule: " + schedule.Name + " due to: " + ex.Message);
                    // Remove linked files (instances and types)
                    List<Element> linkedInstances = new FilteredElementCollector(doc)
                        .OfClass(typeof(RevitLinkInstance))
                        .Where(instance => instance.IsValidObject)
                        .ToList();
                    foreach (Element instance in linkedInstances)
                        if (instance.IsValidObject)
                            try
                                doc.Delete(instance.Id);
                                TaskDialog.Show("Error""Failed to delete linked instance ID: " + instance.Id + " due to: " + ex.Message);
                    List<Element> linkedTypes = new FilteredElementCollector(doc)
                        .OfClass(typeof(RevitLinkType))
                        .Where(linkType => linkType.IsValidObject)
                        .ToList();
                    foreach (Element linkType in linkedTypes)
                        if (linkType.IsValidObject)
                            try
                                doc.Delete(linkType.Id);
                                TaskDialog.Show("Error""Failed to delete linked type ID: " + linkType.Id + " due to: " + ex.Message);
                    transaction.Commit();
                    transaction.RollBack();
                    TaskDialog.Show("Critical Error""An error occurred during the transaction: " + ex.Message);
            TaskDialog.Show("Operation Complete""Views, schedules, and links have been processed as requested.");
dwightduronidavy
SOLVED!
FYI, Herewith resolved new macro:
using System;
using System.Linq;
namespace DDA_CSharpModule4
    [Autodesk.Revit.DB.Macros.AddInId("CC2ECAA5-7631-4A47-96C5-BDD4DFF8073C")]
        #endregion
        public void DeleteSheetsAndViewsRemoveLinkedFiles()
            using (Transaction transaction = new Transaction(doc, "Delete Sheets, Views, and Linked Files"))
                try
                    // Delete sheets except those with specified prefixes
                    List<ViewSheet> sheetsToDelete = new FilteredElementCollector(doc)
                        .OfClass(typeof(ViewSheet))
                        .Cast<ViewSheet>()
                        .Where(sheet => !sheet.Name.StartsWith("Architecture") &&
                                        !sheet.Name.StartsWith("Architectural") &&
                                        !sheet.Name.StartsWith("Landscape") &&
                                        !sheet.Name.StartsWith("Site"))
                        .ToList();
                    foreach (ViewSheet sheet in sheetsToDelete)
                        if (sheet.IsValidObject)
                            try
                                doc.Delete(sheet.Id);
                                TaskDialog.Show("Error"string.Format("Failed to delete sheet: {0}. Error: {1}", sheet.Name, ex.Message));
                    // Delete views except those with suffix "_!", schedules, System Browser, and Project Views
                        .Cast<View>()
                        .Where(view => !view.IsTemplate && !view.Name.EndsWith("_!") &&
                                       view.ViewType != ViewType.Schedule &&
                                       view.ViewType != ViewType.SystemBrowser &&
                                       view.ViewType != ViewType.ProjectBrowser)
                        .ToList();
                            try
                                TaskDialog.Show("Error"string.Format("Failed to delete view: {0}. Error: {1}", view.Name, ex.Message));
                    // Delete schedules except those related to revision numbers and issue dates
                        .Where(schedule => !schedule.Name.Contains("Revision") && !schedule.Name.Contains("Issue Date"))
                        .ToList();
                            try
                                TaskDialog.Show("Error"string.Format("Failed to delete schedule: {0}. Error: {1}", schedule.Name, ex.Message));
                    // Remove all linked Revit files (instances and types)
                        .ToList();
                            try
                                TaskDialog.Show("Error"string.Format("Failed to delete linked instance ID: {0}. Error: {1}", instance.Id, ex.Message));
                        .ToList();
                            try
                                TaskDialog.Show("Error"string.Format("Failed to delete linked type ID: {0}. Error: {1}", linkType.Id, ex.Message));
                    // Remove all linked CAD formats (ImportInstance elements)
                    List<Element> cadFormats = new FilteredElementCollector(doc)
                        .OfClass(typeof(ImportInstance))
                        .Where(cad => cad.IsValidObject)
                        .ToList();
                    foreach (Element cad in cadFormats)
                        if (cad.IsValidObject)
                            try
                                doc.Delete(cad.Id);
                                TaskDialog.Show("Error"string.Format("Failed to delete CAD format ID: {0}. Error: {1}", cad.Id, ex.Message));
                    TaskDialog.Show("Critical Error"string.Format("An error occurred during the transaction: {0}", ex.Message));
            TaskDialog.Show("Operation Complete""Sheets, views, schedules, and linked files have been processed as requested.");
dwightduronidavy
Albeit with a minor error - but still meets my objective
