Default Section type
Hi all,
I'm having trouble setting the default section type. To troubleshoot I tried the following code:
Sub SectionTest(document As Document)
Dim id As ElementId = document.GetDefaultElementTypeId(ElementTypeGroup.ViewTypeSection)
document.SetDefaultElementTypeId(ElementTypeGroup.ViewTypeSection, id) End Sub
But get the following error:
"The element type id typeId is invalid for the give DefaultElementType id defaultTypeId."
Any ideas?
Aaron.Lu
Hi bburling,
Looks like it is a problem.
I've logged an issue:
REVIT-82177 - SetDefaultElementTypeId(ElementTypeGroup.ViewTypeSection, id) throws
Thanks for let us know.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
ok thanks
wouter_vandebergh
I still have this issue with Revit 2019.2. This topic was marked as solved, but it seems the issue is not resolved. Any workaround available?
ElementId defaultGroupTypeId = doc.GetDefaultElementTypeId(ElementTypeGroup.ViewTypeSection);
doc.SetDefaultElementTypeId(ElementTypeGroup.ViewTypeSection, defaultGroupTypeId);
Throws:
An exception of type 'Autodesk.Revit.Exceptions.ArgumentException' occurred in RevitAPI.dll but was not handled in user code
Additional information: The element type id typeId is invalid for the give DefaultElementType id defaultTypeId.
Parameter name: typeId
