Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Creating element in updater typeof "GetChangeTypeElementAddition"
3 REPLIES 3
ollikat
584 Views, 3 Replies
Hi all Revit API masters 🙂
Doesn anyone have an experience in following situation?
I have an updater which is triggered by element additions (Element::GetChangeTypeElementAddition()). Within the Execute of that updater an another element is created (a tag element).
In previous Revit release this again caused triggering of updater(s) of "addition" type. But seems that in Revit 2013 it's not the case anymore(?). It seems that elements (at least tags) added inside the addition updater doesnt' cause further triggering of similar updaters.
Can anyone confirm or disprove this?
Thanks!
3 REPLIES 3
augusto.goncalves
in reply to: ollikat
This is not listed on the "Revit Platform API Changes and Additions.docx" for 2013, so if you believe anything changed, then we need to investigate deeper. Can you provide more information or sample code on it? Please don't share confidential information or, if you are a ADN member, then you can log a case.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Dear Olli,
Thank you for reporting this. I submitted a change request SPR #234298 [Updater difference between 2012/2013] on your behalf for further exploration.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
ollikat
in reply to: jeremytammik
Any time Jeremy 🙂
I marked this as solved, although the issue stille exists, but in scope of this forum, this question is dealt now.
Thank you too!
Rail Community
