Creating a pipe or flex pipe by loading a family
I'm completely new to the Revit API and am having trouble simply loading a family and using it to create a pipe or flex pipe. I'm sure there is something simple I am missing, and I've had success with things like doors and tables, however I'm completely baffled with creating even a simple pipe that goes from A to B beyond just the default pipe option (I've included the code I used to make a default flex pipe and default pipe - my only success). I have not been successful in finding example code online (I have scoured The Building Coder and have not found enough pieces to put this together). If someone can give me a basis to work from I would be so grateful.
Working FlexPipe:
        private static void CreateFlexPipe(Document newDoc, Wall wall)
            FilteredElementCollector collector = new FilteredElementCollector(newDoc);
            collector.OfClass(typeof(FlexPipeType));
            ElementId pipeTypeId = collector.FirstElementId();
            FilteredElementCollector sysCollector = new FilteredElementCollector(newDoc);
            sysCollector.OfClass(typeof(PipingSystemType));
            ElementId pipeSysTypeId = sysCollector.FirstElementId();
            Level levelId = newDoc.GetElement(wall.LevelId) as Level;
            FlexPipe pipe = null;
            if (pipeTypeId != ElementId.InvalidElementId && pipeSysTypeId != ElementId.InvalidElementId)
                List<XYZ> points = new List<XYZ>();
                points.Add(new XYZ(0, 0, 0));
                points.Add(new XYZ(10, 10, 0));
                points.Add(new XYZ(10, 0, 0));
                pipe = FlexPipe.Create(newDoc, pipeSysTypeId, pipeTypeId, levelId.Id, points);
Working Pipe:
        private static void CreatePipe(Document newDoc, Wall wall)
            collector.OfClass(typeof(PipeType));
            Pipe pipe1 = null;
                XYZ p1 = new XYZ(0, 0, 0);
                XYZ p2 = new XYZ(10, 10, 0);
                pipe1 = Pipe.Create(newDoc, pipeSysTypeId, pipeTypeId, levelId.Id, p1, p2);
Also here is where I am at with trying to load a family:
private static void TestLoadFamily(Document newDoc)
            string filename = @"C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric\Pipe\Actual Pipe\JONATHAN39S_METRIC_PIPE_HORIZONTAL_30MM_PIPE_THICK_2825.rfa";
            FilteredElementCollector levelCollector = new FilteredElementCollector(newDoc);
            levelCollector.OfClass(typeof(Level));
            ElementId someLevelId = levelCollector.FirstElementId();
            using (Transaction familyTrans = new Transaction(newDoc, "Use a Family"))
                familyTrans.Start();
                Family family = null;
                if (!newDoc.LoadFamily(filename, out family))
                    throw new Exception("Unable to load " + filename);
                ISet<ElementId> familySymbolIds = family.GetFamilySymbolIds();
                int count = 0;
                foreach (ElementId id in familySymbolIds)
                    if (count == 0)
                        FamilySymbol pipeSymbol = family.Document.GetElement(id) as FamilySymbol;
                        if (!pipeSymbol.IsActive)
                            pipeSymbol.Activate();
                            newDoc.Regenerate();
                        Pipe pipe = null;
                        pipe = Pipe.Create(newDoc, pipeSysTypeId, pipeSymbol.Id, someLevelId, p1, p2);
                    count++;
                familyTrans.Commit();
This errors with: "The pipe type pipeTypeId is not valid pipe type."
*Note: I am using the DesignAutomationHandler and build within another project.
s.borello
Don't know what you're trying to do...seems like you're overthinking a bit.  Plus, there is an API forum where you may get more attention.  I would just toggle on the system tab: piping tools, and model the pipe that way.  Good luck!
Thank you, I will re-post in that forum.
s.borello
If you want you can simply report your post to admin and they will move it for you, rather than recreate the post.
Thanks again, I've already copied and pasted the post 🙂
