Block Revit while Windows Form is running
franjavigarciavalencia
I would like to block the use of Revit while my plugin runs a certain functionality (in this case, it opens a Windows Form, and I want Revit to be unusable while that Form is open) just like when you want to modify the visibility of a view and it won't allow you to do anything else until you finished any modification.
Is there any method to do this directly?
Thank you.
PavelAnd
Hi @franjavigarciavalencia. I always thought that if you use System.Windows.Forms after Form.ShowDialog() Revit becomes unusable. All my forms work this way…
Best regards, Pavel Plotitsyn.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @franjavigarciavalencia ,
Understand the difference between modal dialog and modeless dialog.
Dialog Guidelines
Create a modal dialog to block Revit while Form is running.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremytammik
I fully agree with Pavel and Naveen.
If your external Windows functionality is in a separate application, you could still block Revit by launching an external command presenting a modal Windows form, blocking Revit, and use the Windows API or .NET libraries to send a message to close that form and terminate the external command once your external application has done its dirty deed.
Jeremy Tammik
The Building Coder
I see, I thought it was something related to the Revit UI and not to Forms itself.
Thank you all for your help!
