Creating a picture of a door type without adding a door instance to a project
Hello everyone
I am writing a Revit Add-In in Revit API 2015.  It has a dialog that shows pictures of door types.  The way I create a picture is like this:
1. I create a wall in the project and put a door instance in the wall.
2. I get the geometry of the door by calling the get_Geometry method of the FamilyInstance class for the door instance
3. When I have retrieved the geometry I delete the wall instance and the door instance because I don't want them in the project.
4. I then create a picture of the door as seen from above using the data in the GeometryElement object that I got from the door instance.
There is an Add-In in the Revit SDK Samples folder that does this same thing.  It is called DoorSwing.
What I want is to get a overhead picture of a door type without creating an actual door instance in the project.  Does anybody have an idea on how this could be done?
Greetings Ari
Joe.Ye
Revit type parent class ElementType provides GetPreViewImage() method to retrieve the type's image.
Hope this method helps you.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Not what I was looking for but thanks anyway.  What I want is an overhead picture of a door.
