Create VIEW TYPES
Create VIEW TYPES
GallowayUS_com_RonAllen2
Message 1 of 27
Create VIEW TYPES
Is there a way to create/remove view types through the API?
To clarify what I mean-  manual process in Revit is here: (Create a view type)
You can create view types for plans, elevations, sections, 3D views, drafting views, legends, and schedules.
  1. Open a view for which you want to create a view type, or click the view name in the Project Browser.
  2. In the Properties palette, click Edit Type.
  3. In the Type Properties dialog, click Duplicate.
  4. Enter a name for the new view type and click OK.
  5. In the Type Properties dialog for the new view type, specify a value for each Graphics parameter.
I haven't found reference in the API yet- but just started searching. Seems to be scarce and I am a little concerned as you cannot get view types thorugh a transfer project standards.
 @jeremytammik
Ron Allen
Galloway BIM
Replies (26)
Message 21 of 27
This works:
##https://forum.dynamobim.com/t/python-create-new-viewfamilytype/37755
import clr
#Import the Revit API
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.DB import *
#Import DocumentManager and TransactionManager
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
#from RevitServices.Transactions import TransactionManager
#Reference the active Document and application
doc = DocumentManager.Instance.CurrentDBDocument
##fec = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements() ##Works returns ViewFamilyTypes
#vft = [x.Id for x in fec if x.ViewFamily == ViewFamily.StructuralPlan][0] #This gets the Id of the ViewFamilyType,
	#and is sort of what Jeremy does with the Linq method, but it i don't think it can be implemented the same way.
	#Instead I'm using a list comprehension.
OUT = fec
This from Sean Page works:
#Sean Page, 2021
#https://forum.dynamobim.com/t/view-family-types-selection/22359/15
import clr
from Autodesk.Revit.DB.Structure import *
clr.AddReference('RevitAPIUI')
from Autodesk.Revit.UI import *
clr.AddReference('System')
from System.Collections.Generic import List
clr.AddReference('RevitNodes')
import Revit
clr.ImportExtensions(Revit.GeometryConversion)
clr.ImportExtensions(Revit.Elements)
uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
#Preparing input from dynamo to revit
names = IN[0]
results = []
#Do some action in a Transaction
#TransactionManager.Instance.EnsureInTransaction(doc)
ViewFamilyTypes = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
for name in names:
    for VFT in ViewFamilyTypes:
        nm = VFT.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString()
        if  name == nm:
            results.append(VFT)
#TransactionManager.Instance.TransactionTaskDone()
OUT = results
Ron Allen
Galloway BIM
Message 22 of 27
RPTHOMAS108
Message 23 of 27
Edited the wrong post : (
Warning: TypeError : No method matches given arguments for Duplicate: () ['  File "<string>", line 113, in <module>\n', '  File "<string>", line 99, in GetDraftingViewTypeByName\n']
# Load the Python Standard and DesignScript Libraries
import sys
import clr
##https://forum.dynamobim.com/t/collecting-all-elements-of-family-types-in-active-view/19838/2
from Autodesk.Revit.DB import FilteredElementCollector
#  Drafting Views
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, BuiltInParameter
from Autodesk.Revit.DB import ViewFamilyType, ViewDrafting, Element
from Autodesk.Revit.DB import Transaction
def GetDraftingViews():
    ##https://forums.autodesk.com/t5/revit-api-forum/view3d-collector/td-p/5277451
    DraftingViewsList = FilteredElementCollector(doc).OfClass(ViewDrafting).ToElements()
    ##DraftingViewTemplates = [v.Id for v in DraftingViewsList if v.IsTemplate == True]
    DraftingViewsList = [v for v in DraftingViewsList if v.IsTemplate == False]
    return [DraftingViewsList]
def GetDraftingViewTemplates():
    DraftingViewTemplates = [v for v in DraftingViewsList if v.IsTemplate == True]
    ##DraftingViewsList = [v.Id for v in DraftingViewsList if v.IsTemplate == False]
    return [DraftingViewTemplates]
def GetNameByID(oID):  ##GenericAnnotationFamilyType".Name"
    return doc.GetElement(oID).get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString()
def GetDraftingView_AllTypes():                         ##Returns all draft view family types
    viewfamily_types = FilteredElementCollector(doc).OfClass(ViewFamilyType)
    DraftViewTypes=[]
    for i in viewfamily_types:
        if i.ViewFamily == ViewFamily.Drafting:         ##*.ViewFamily Backwards 'parent' ref I've been looking for!##<<<<<<<<<<<<<<<<<<<<<<<<<<HERE
            DraftViewTypes.append( i)
    return DraftViewTypes
def GetDraftingViewByBame(strName=""):                  ##Check if drafting view existds = if not, create it and assign view name
    if not strName == "":                               ##If string name is set look for the drafting view
        DraftingView = FilteredElementCollector(doc).OfClass(ViewDrafting).ToElements()  ##Get all drafting views
        DraftingView = [v for v in DraftingView if v.Name == strName]   ##Return Drafting view for each Drafting view eq. Name
        if DraftingView:
            DraftingView =DraftingView[0] ##Return single item not list<<<<<<<<<<<<<<<
    if not DraftingView:                                ##If no drafting view found
        drafting_type_id = get_drafting_type_id()       ##Get TYPE ID
        DraftingView = ViewDrafting.Create(doc, drafting_type_id)   ##Create View
        ##After creating view-
        if not strName=="" :                            ##IF string is not null set the name of the new view
            DraftingView.Name = strName
    return DraftingView                                 ##Return single value
def GetDraftingViewType():
    ##Selects First available ViewType that Matches Drafting Type.##
            return i
    ##If view doesn't exist create and delete
def Main():
    ##draftview = get_drafting_type()
    viewfamily_types = UnwrapElement(FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements())
    ##viewfamily_types = UnwrapElement(FilteredElementCollector(doc).OfClass(ViewFamilyType).OfClass(ViewDrafting))
    return viewfamily_types
    #return GetNameByID(viewfamily_types)
def GetDraftingViewTypeByName(DraftViewTypeName=""): ##Returns Default "Drafting View" ViewType or name as specified or creates ViewType by DraftViewTypeName
    ##Trans_GDVBTN = Transaction (doc, 'Drafting View Type')
    ##Trans_GDVBTN.Start()
    ##Get all View_Family_Types from Drafting Views:
    DraftViewTypes = [ x for x in FilteredElementCollector(doc).OfClass(ViewFamilyType) if x.ViewFamily == ViewFamily.Drafting ]
    found=False                                         ##Found as false
    if not DraftViewTypeName == "":                     ##If view name is not null
        for DraftViewType in DraftViewTypes:    ##<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<DEBUG
            #return GetNameByID(v.Id) ##<<<<<<<<<<<<<<<<<THIS WORKS TO GET THE NAME
            #return v.Name ##<<<<<<<<<<<<<<<<<<<<<<<<<<<<THIS BREAKS
            #return type(v),dir(v) ##<<<<<<<<<<<<<<<<<<<<List all methods / Properties
            if GetNameByID(DraftViewType.Id) == DraftViewTypeName:
                found=True
                break
    if not found:
        DraftViewType = None
    ##FAILS##viewfamily_types = [v for v in viewfamily_types if v.Name == strName]   ##Return Drafting view for each Drafting view eq. Name
    if DraftViewType == None:                           ##If no DraftingViewType found
        ##Duplicate existing type
        ##REname copy ##NOTE Must be in transaction to rename and apply!
        DraftViewTypes = DraftViewTypes[0]              ##Set to base type
        DraftViewType = DraftViewTypes.Duplicate        ##(strName) as ViewFamilyType
        ##After Duplicating viewType-
        if not DraftViewTypeName=="" :                  ##IF string is not null set the name of the new view
            DraftViewType.Name = DraftViewTypeName
    ##Trans_GDVBTN.Commit()                               ##Commit transaction - will see if we can do paralell with another transaction per API
    return DraftViewType                               ##Return list
t = Transaction (doc, 'Create Drafting View Type')
t.Start()
DVT=GetDraftingViewTypeByName("Test3") ## GetDraftingView_AllTypes()
#DVT=GetDraftingView_AllTypes()
#DVT[1].Name="Test2"                                     ##Works... but cannot read DVT[1].Name??? BUG in Pyhon PER:.Name
#DVT = [I.Name for I in DVT]
##OUT =DVT[0].Name  ##[v.Name for v in DVT]             ##Cannot Read?
#OUT=GetDraftingViewTypeByName ("NewType")
##GetDraftingView ()
OUT=DVT
t.Commit()
Where:
##Quick return of some of the variables
return type(DraftViewTypes), type(ViewFamilyType), dir(DraftViewTypes)
    Autodesk.Revit.DB.ViewFamilyType,  ##RETURN Type of "DraftViewTypes"
    <class 'CLR.CLR Metatype'>,        ##RETURN Type of our variable  (ViewFamilyType)
    [                                  ##Return dir() of our variable
      ArePhasesModifiable,
      AssemblyInstanceId,
      CanBeCopied,
      CanBeDeleted,
      CanBeHidden,
      CanBeLocked,
      CanBeRenamed,
      CanDeleteSubelement,
      CanHaveAnalyticalModel,
      CanHaveTypeAssigned,
      Category,
      ChangeTypeId,
      CreatedPhaseId,
      DefaultTemplateId,
      DeleteEntity,
      DeleteSubelement,
      DeleteSubelements,
      DemolishedPhaseId,
      DesignOption,
      Dispose,
      Document,
      Duplicate,                       ##Duplicate is an optoion...
      Equals,
      FamilyName,
      Finalize,
      GetAnalyticalModel,
      GetAnalyticalModelId,
      GetChangeTypeAny,
      GetChangeTypeElementAddition,
      GetChangeTypeElementDeletion,
      GetChangeTypeGeometry,
      GetChangeTypeParameter,
      GetDependentElements,
      GetEntity,
      GetEntitySchemaGuids,
      GetExternalFileReference,
      GetExternalResourceReference,
      GetExternalResourceReferences,
      GetGeneratingElementIds,
      GetGeometryObjectFromReference,
      GetHashCode,
      GetMaterialArea,
      GetMaterialIds,
      GetMaterialVolume,
      GetMonitoredLinkElementIds,
      GetMonitoredLocalElementIds,
      GetOrderedParameters,
      GetParameter,
      GetParameterFormatOptions,
      GetParameters,
      GetPhaseStatus,
      GetPreviewImage,
      GetSimilarTypes,
      GetSubelements,
      GetType,
      GetTypeId,
      GetValidTypes,
      GroupId,
      HasPhases,
      Id,
      IsCreatedPhaseOrderValid,
      IsDemolishedPhaseOrderValid,
      IsExternalFileReference,
      IsHidden,
      IsMonitoringLinkElement,
      IsMonitoringLocalElement,
      IsPhaseCreatedValid,
      IsPhaseDemolishedValid,
      IsSimilarType,
      IsTransient,
      IsValidDefaultFamilyType,
      IsValidDefaultTemplate,
      IsValidObject,
      IsValidType,
      LevelId,
      Location,
      LookupParameter,
      MemberwiseClone,
      Name,
      Overloads,
      OwnerViewId,
      Parameters,
      ParametersMap,
      Pinned,
      PlanViewDirection,
      ReferenceEquals,
      RefersToExternalResourceReference,
      RefersToExternalResourceReferences,
      ReleaseUnmanagedResources,
      SetEntity,
      ToString,
      UniqueId,
      VersionGuid,
      ViewFamily,
      ViewSpecific,
      WorksetId,
      __call__,
      __class__,
      __delattr__,
      __delitem__,
      __dir__,
      __doc__,
      __enter__,
      __eq__,
      __exit__,
      __format__,
      __ge__,
      __getattribute__,
      __getitem__,
      __gt__,
      __hash__,
      __init__,
      __init_subclass__,
      __iter__,
      __le__,
      __lt__,
      __module__,
      __ne__,
      __new__,
      __overloads__,
      __reduce__,
      __reduce_ex__,
      __repr__,
      __setattr__,
      __setitem__,
      __sizeof__,
      __str__,
      __subclasshook__,
      getBoundingBox,
      get_AssemblyInstanceId,
      get_BoundingBox,
      get_CanBeCopied,
      get_CanBeDeleted,
      get_CanBeRenamed,
      get_Category,
      get_CreatedPhaseId,
      get_DefaultTemplateId,
      get_DemolishedPhaseId,
      get_DesignOption,
      get_Document,
      get_FamilyName,
      get_Geometry,
      get_GroupId,
      get_Id,
      get_IsTransient,
      get_IsValidObject,
      get_LevelId,
      get_Location,
      get_Name,
      get_OwnerViewId,
      get_Parameter,
      get_Parameters,
      get_ParametersMap,
      get_Pinned,
      get_PlanViewDirection,
      get_UniqueId,
      get_VersionGuid,
      get_ViewFamily,
      get_ViewSpecific,
      get_WorksetId,
      setElementType,
      set_CreatedPhaseId,
      set_DefaultTemplateId,
      set_DemolishedPhaseId,
      set_Name,
      set_Pinned,
      set_PlanViewDirection
Ron Allen
Galloway BIM
Message 24 of 27
Two seconds after I posted that tried yet another variation and it worked!
OUT=DVT
and:
Creates it if it doesn't exist AND passes it back if it does!
import sys
import clr
#  Drafting Views
    DraftViewTypes=[]
        if DraftingView:
            return i
def Main():
                found=True
                break
    if not found:
        DraftViewType = DraftViewTypes.Duplicate(DraftViewTypeName)        ##(strName) as ViewFamilyType
t.Start()
OUT=DVT
t.Commit()
Ron Allen
Galloway BIM
Message 25 of 27
H.echeva
Thank you very much for the post, this helped me a lot.
I created the following C# macros based in your information. I hope they can be useful.
The macros will copy the ViewFamilyTypes from another document to the current document.
The first one will only copy the ViewFamilyTypes and not the associated template. The second will include the associated View templates but these must exist already in the target document (use another macro for that or transfer standards tool in Revit).
First Macro without view templates:
/// <summary>
		/// This copies Plan familyviewtypes to the current document from another document.
		/// This will only duplicate the name, it won't include the associated template
		/// </summary>
		public void CopyViewTypes()
			Document targetDoc = this.ActiveUIDocument.Document;
			Document sourceDoc=null;
			foreach(Document d in this.Application.Documents)
				if(d!=targetDoc && !d.IsLinked)
					sourceDoc=d;
			FilteredElementCollector sourceViewTypeCollector = new FilteredElementCollector(sourceDoc);
			List<string> sourcePlanTypes = sourceViewTypeCollector.OfClass(typeof(ViewFamilyType))
				.Cast<ViewFamilyType>()
				.Where(x=>x.ViewFamily==ViewFamily.FloorPlan)
				.Select(x=>x.Name)
				.ToList();
			List<ViewFamilyType> floorPlanTypes = new List<ViewFamilyType>();
			FilteredElementCollector targetViewTypeCollector = new FilteredElementCollector(targetDoc);
			ViewFamilyType typeToDuplicate = targetViewTypeCollector.OfClass(typeof(ViewFamilyType)).Cast<ViewFamilyType>().Where(x=>x.ViewFamily== ViewFamily.FloorPlan).FirstOrDefault();
			using(Transaction t = new Transaction(targetDoc,"Copy View types"))
				t.Start();
					foreach(string s in sourcePlanTypes)
						if(s=="Floor Plan") continue;
						typeToDuplicate.Duplicate(s);
				t.Commit();
The second macro will include the associated view templates:
/// <summary>
		/// This will include the associated view template but the template must already exist in the target document.
		/// Use another macro to copy the view templates first
		/// </summary>
		public void CopyViewTypesWithTemplate()
					sourceDoc=d;
			IEnumerable<ViewFamilyType> sourcePlanTypes = sourceViewTypeCollector.OfClass(typeof(ViewFamilyType))
				.Where(x=>x.ViewFamily==ViewFamily.FloorPlan);
				.FirstOrDefault();
				t.Start();
					foreach(ViewFamilyType s in sourcePlanTypes)
						if(s.Name=="Floor Plan") continue;
						string templateName = sourceDoc.GetElement(s.DefaultTemplateId).Name;
						FilteredElementCollector viewTemplateCollector = new FilteredElementCollector(targetDoc);
						ElementId templateId = viewTemplateCollector.OfClass(typeof(ViewPlan))
												.Cast<ViewPlan>()
												.Where(x=>x.IsTemplate && x.Name==templateName)
												.Select(x=>x.Id)
												.FirstOrDefault();
						ViewFamilyType newViewFamilyType = typeToDuplicate.Duplicate(s.Name) as ViewFamilyType;
						newViewFamilyType.DefaultTemplateId=templateId;
				t.Commit();
Message 26 of 27
Nice! Great way to pay it forward.
I am getting into API development and this will save some grief converting from PY to C# : )
Ron Allen
Galloway BIM
Message 27 of 27
hwo_osa
For those of you still struggling with this in 2025, there is actually a very simple way to do this in Dynamo, using the built-in Element.ElementType and ElementType.Duplicate nodes. You can even input a list of multiple names for the newly created duplicates to automate things further:
Best regards
Henrik
