Create UI for Revit 2025 based .Net 8
manhgt214
manhgt214
From Revit 2025 based .Net 8 so I can't add a class WPF or Windows Form.
So how to create UI in .Net 8
Use Avalonia like wpf?
Many Thanks!
Mohamed_Arshad
Hi @manhgt214
You have missing tag in the csproj. Check your csproj file and add below tag in the csproj. Restart the visual studio after adding the below tags.
<!--If you need add WPF use below tag-->
<UseWPF>true</UseWPF>
<!--If you need add WindowForm use below tag-->
<UseWindowsForms>true</UseWindowsForms>
<!--If your plugin has both WPF and Winform the use both-->
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
manhgt214
Thank @Mohamed_Arshad,!
I added that text to "csproj" then can add WPF & WinForm
but both not work.
Mohamed_Arshad
Hi @manhgt214
You are missing tag in csproj. I have created a sample Revit API project, Kindly check the attached project.
<PropertyGroup>
	<TargetFramework>net80-windows</TargetFramework>
	<LangVersion>latest</LangVersion>
	<ImplicitUsings>enable</ImplicitUsings>
	<Nullable>enable</Nullable>
</PropertyGroup>
Hope this will Helps 🙂
Mohamed Arshad K
manhgt214
Thank you!
my project not work coz default is multi platform
I need change to windows.
default is: <TargetFramework>net8.0</TargetFramework>
need change to:
or
<TargetFramework>net8.0-windows</TargetFramework>
Mohamed_Arshad
Hi @manhgt214
Yeah I have noticed that one, So only created a sample project and shared with you. Happy that your problem has been solved !. Happy Coding:)
Mohamed Arshad K
