Add Schedule to sheet
sensiblehira
sensiblehira
Hello, I wanted to find the command to add a schedule to a sheet. Can anyone help out.
ChatGPT is not giving the correct answer.
sensiblehira
Found the ScheduleSheetInstance class
Chuong.Ho
You can easy to do it by using Create from class ScheduleSheetInstance :
var document = commandData.Application.ActiveUIDocument.Document;
var viewSheetID = document.ActiveView.Id;
var scheduleId = new ElementId(123456); // Replace with your schedule ID
ScheduleSheetInstance scheduleInstance = ScheduleSheetInstance.Create(document,viewSheetID,scheduleId,new XYZ(0,0,0));
Chuong Ho
