Hi everyone!. Im new in programming. I´ve been developing some macros with C#.
In this case, im trying to create schedules (gross and rentable área Schedule), with a API.
It would be very useful if you can show me some example of the code needed.
Thanks a lot!.
Thanks a lot!.
Solved by matthew_taylor. Go to Solution.
Hi Matias,
There are examples of this in the SDK. Try to adapt them to your needs.
There is a link to the SDK on this page: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
Post again if you need help with a specific issue.
Cheers,
Matt
Hi Matias,
Cheers,
Matt
Hi Matias
Additionaly you can check this website:
http://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
Hi Matias
