Create.NewReferencePlane
I have a dxf file with some lines in it. I would like to import these lines in to Revit as reference line. How can I do this with Revit API ?
In dxf , there is X,Y,Z coordinates of start point of a line and end points of a line. Like : StartPoint X:20 ,Y:30, Z:11,
End Point : X:21, Y:31, Z:0 . Can I draw this line as a reference line?  If I can try to draw this as ReferencePlane, this time I couldn't understand the cutVec of this function.
If I use it like this :
 // Create Plane 2
        XYZ freeEnd2 = new XYZ(20, 30, 11);
        XYZ bubbleEnd2 = new XYZ(21, 31, 0);
        ReferencePlane refPlane2 =
          doc.Create.NewReferencePlane(
          bubbleEnd2,
          freeEnd2,
          XYZ.BasisZ,
          doc.ActiveView);
this time there is an error like  "Input geometry is not correct to lay out the reference plane"..
Please help me.. Thanks..
saikat
Hi
This post might be of help in clarifying how to use the NewRefrencePlane():
http://adndevblog.typepad.com/aec/2013/01/bubble-end-and-free-end-in-newreferenceplane.html
cheers
Saikat Bhattacharya
Senior Manager - Technology Consulting
