06:08 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello! I want to create Dimension between selected points.
I attach my code.
When I do this code, I catch an exception Autodesk.Revit.Exceptions.InvalidOperationException.
How can I fix it??
#region Namespaces
using System;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
#endregion
namespace PickObject
[Transaction(TransactionMode.Manual)]
public class Command : IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
using (Transaction tx = new Transaction(doc))
tx.Start("Start");
PickPoint(uidoc, app);
tx.Commit();
return Result.Succeeded;
public void PickPoint(UIDocument uidoc, Application app) {
View activeView = uidoc.ActiveView;
SketchPlane sketch = activeView.SketchPlane;
ObjectSnapTypes snapTypes = ObjectSnapTypes.Endpoints | ObjectSnapTypes.Intersections | ObjectSnapTypes.Points | ObjectSnapTypes.Perpendicular;
XYZ startPoint;
XYZ endPoint;
Plane geometryPlane = Plane.CreateByNormalAndOrigin(XYZ.BasisZ, XYZ.Zero);
sketch = SketchPlane.Create(uidoc.Document, geometryPlane);
uidoc.Document.ActiveView.SketchPlane = sketch;
uidoc.Document.ActiveView.ShowActiveWorkPlane();
try
startPoint = uidoc.Selection.PickPoint(snapTypes, "Select start point");
endPoint = uidoc.Selection.PickPoint(snapTypes, "Select end point");
catch(Autodesk.Revit.Exceptions.OperationCanceledException oc)
Console.WriteLine(oc.Message);
return;
catch(Autodesk.Revit.Exceptions.InvalidOperationException oe)
Console.WriteLine(oe.Message);
TaskDialog.Show("Revit", "No work plane set in current view.");
return;
catch (Autodesk.Revit.Exceptions.ArgumentNullException n)
Console.WriteLine(n.Message);
return;
} //Выбор точек
double dist = startPoint.DistanceTo(endPoint);
string distance = "Distance is " + dist.ToString();
string strCoords = "Selected start point is " + startPoint.ToString() + "\nSelected end point is " + endPoint.ToString() + distance;
Line line = Line.CreateBound(startPoint, endPoint);
CreateLinearDimension(uidoc.Document, startPoint, endPoint, sketch, app);
TaskDialog.Show("Revit", strCoords);
public Dimension CreateLinearDimension(
Document doc, XYZ pt1, XYZ pt2, SketchPlane sketch, Application app)
// first create line
Line line = Line.CreateBound(pt1, pt2);
ModelCurve modelcurve = doc.Create
.NewModelCurve(line, sketch);
ReferenceArray ra = new ReferenceArray();
ra.Append(modelcurve.GeometryCurve.Reference);
return doc.Create.NewDimension(doc.ActiveView, line, ra);
