Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Create ArchitecturalWall
6 REPLIES 6
546 Views, 6 Replies
Can someone help me with an examplecode for creating a new Wall:Architectural?
I wish to insert a radius/allow the wall to follow a curve.
Now my curves are within the CurveArray category and created as follows;
CurveArray curve1= new CurveArray();
Arc path = CreateArcByGivingPlane(plane, r, angle1, angle2);
curve1.Append(path);
Thank you.
Thank you.
6 REPLIES 6
Moustafa_K
Moustafa_K
try reading this and let us know if you successfully able to create a wall from cuve
https://forums.autodesk.com/t5/revit-api-forum/intro-to-revit-api-create-wall-from-location-line-or-...
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Moustafa Khalil
naveen.kumar.t
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Here is an example code
 XYZ origin = new XYZ(0, 0, 0);
                XYZ normal = new XYZ(0, 0,10);
                Plane p = Plane.CreateByNormalAndOrigin(normal,origin);
                SketchPlane sp = SketchPlane.Create(doc, p);
                IList<Curve> curvess = new List<Curve>();
                Arc path = Arc.Create(p, 35, Math.PI / 2, Math.PI);
                curvess.Add(path);
                Level level1;
                Wall.Create(doc, path, level1.Id, false);
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi @Anonymous ,
                curvess.Add(path);
                Level level1;
I hope this helps.
Naveen Kumar T
in reply to: naveen.kumar.t
I have tried this earlier, but I guess I defined something wrong, cause now it worked.
Thank you!
How do I set the height of the wall?
Thank you!
Moustafa_K
Moustafa_K
naveen.kumar.t
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To set the height of the wall
Wall w;
int heightofWall; if(w!=null) { Parameter P1 = w.get_Parameter(BuiltInParameter.WALL_USER_HEIGHT_PARAM); if(P1!=null) { P1.Set(heightofWall); } }
Naveen Kumar T
Hi @Anonymous ,
Wall w;
Naveen Kumar T
Thank you, that worked perfectly 😄
