Create a grid with text color.
sizy458
sizy458
I would like to create in Dotnet in the Revit document a "Grid" 'Autodesk.Revit.DB.Grid'
with color of the text of the bubble set.
How do i do ?
Thank.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sizy458 ,
You create a grid and use OverrideGraphicSettings to change the color of the grid.
Grid G=Grid.Create(doc,Line);
ElementId eid = G.Id;
OverrideGraphicSettings ORGS = new OverrideGraphicSettings();
Color c = new Color(redValue,greenValue,blueValue);
ORGS.SetProjectionLineColor(c);
doc.ActiveView.SetElementOverrides(eid, ORGS);
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
sizy458
Yes,
But how fix for text color ?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sizy458 ,
 I am checking with the development team for you.
 Have you tried to achieve the same functionality via UI?
If it is possible via UI then it is also possible via API.
Naveen Kumar T
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sizy458 ,
I don't think you can do just the name in the UI.
Generally, the API doesn't have more functionality than the UI.
Naveen Kumar T
