Course Fills Inconsistent on same wall type
miriamNHCLP
miriamNHCLP
Community Visitor
Community Visitor
Hello
I have a number of walls on a plan & they are the same type, height, offset etc however on the plan only 1 is showing the desired course colour fill (pink).
The only difference I can see is that the "pink"one says "top is attached" even though I have pressed "detach".
Any suggestions?
Thank you.
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
