So the custom parameters exist, are spelled correctly and etc... What is strange is that one of them I am able to set but the rest I can not via the API... Any ideas on why this is not working?
ViewSheet v = null;
v = ViewSheet.Create(doc, titleblockid);
v.Name = s.sheetTitle;
v.SheetNumber = s.sheetNumber;
Parameter p = null;
// DOES NOT WORK
p = v.LookupParameter("SHEET DISCIPLINE");
if (!p.SetValueString("turkey"))
TaskDialog.Show("Error", "Failed to set discipline param");
// WORKS
p = v.LookupParameter("SHEET SORT CATEGORY");
if (!p.Set(123456))
TaskDialog.Show("Error", "Failed to set sort category param");
// DOES NOT WORK
p = v.LookupParameter("SHEET USE");
if (!p.SetValueString("Lamb"))
TaskDialog.Show("Error", "Failed to set use param");
// DOES NOT WORK
p = v.LookupParameter("SHEET SORT CODE");
if (!p.SetValueString("chicken"))
TaskDialog.Show("Error", "Failed to set sort code param");
Solved by RPTHOMAS108. Go to Solution.
SetValueString is for setting value types e.g. 5' - 10 1/4"
I would put the above imperial units in quote marks but that would just be confusing.
The one that works uses 'Set'.
Ahh thank you!
