- Mute
- Permalink
- Report
we have a piece if code, that's running fine on every machine that we tested it on, but on some user's PC it will always throw a CorruptModelException with this message: "The model could not be saved: Unbekannter Fehler beim Zugriff auf eine unbenannte Datei. (CArchiveException 1)"
(translation of the german part: unknown error while accessing an unnamed file)
This error seems to be impossible to reproduce on my system.
Heres the failing code. I believe, the Exception is thrown in the last line.
Document doc = null;
if (docTemplatePath.EndsWith(".rte"))
doc = app.Application.NewProjectDocument(docTemplatePath);
else
doc = app.Application.OpenDocumentFile(docTemplatePath);
SaveAsOptions saveAsOptions = new SaveAsOptions();
saveAsOptions.OverwriteExistingFile = true;
if (activateWorksharing != null && activateWorksharing == "true")
doc.EnableWorksharing(WWBRevitApp.resourceManager.GetString("WWBRevitEventHandler_WorksetName"), WWBRevitApp.resourceManager.GetString("WWBRevitEventHandler_WorksetNameGridLevel"));
WorksharingSaveAsOptions worksharingSaveAsOptions = new WorksharingSaveAsOptions();
worksharingSaveAsOptions.SaveAsCentral = true;
worksharingSaveAsOptions.OpenWorksetsDefault = SimpleWorksetConfiguration.AllWorksets;
saveAsOptions.SetWorksharingOptions(worksharingSaveAsOptions);
doc.SaveAs(docCreateNewPath, saveAsOptions);
I assumed, that maybe the user passes a path, he doesn't have write access on, but the exception seems to be thrown no matter what path he uses. The .rte file he uses seems to be ok as well. As I said, the code would run fine on my machine using the same template file. If he creates a new project with that template file manually, everything is fine as well.
I'm kinda out of ideas, what the problem might be. Anybody seen this error before?
Andreas
