Copy/Monitor elements from linked file
blueeye1371
blueeye1371
I'm curious if there's a method to copy or monitor elements from a linked file. For instance, I can duplicate grids from a Revit linked file, but I'm unable to monitor them using the Revit API.
Could you assist me with this?
Thank you.
jeremy_tammik
I am not sure this is covered by the Revit API. There are a couple of open wishes for suchlike functionality in the Revit Idea Station:
https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
For instance, a long-standing wish for a Copy/Monitor API:
https://forums.autodesk.com/t5/revit-ideas/copy-monitor-api/idi-p/6322737
Please add your vote to the appropriate ones.
That said, there may also be ways that I am not aware of to achieve your specific needs with the existing API.
