Copy materials between Family Docs
josepht21
josepht21
Hey,
I'm seeing a change in behavior when copying materials between documents using the Revit API. Back in Revit 2022, if I copied a material that had the same name as one in the target doc, it would just override it. Now in Revit 2024, doing the exact same thing creates a duplicate instead (e.g. MyMaterial becomes MyMaterial1), instead of replacing the existing one.
Any idea how to get back the old behavior where the material gets overridden? I’m stuck and a bit pressed for time, so any help would be super appreciated.
Thanks! Joseph
ricaun
I noticed that behavior recently when tried to copy families between documents using:
I was testing in Revit 2026 and show a warning mention the name change. I didn't find a way to overwrite at the moment 🙁
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
