Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Copy elements between documents with same Project Base Point
1 REPLY 1
erron_e
581 Views, 1 Reply
I am trying via API to copy elements from one open document to another. They have the same project base point. However, on copying, the elements are not in the correct place. I assumed that using no Transform they would end up in the same place but it seems not. Is there a way to specify copying on Project Base Point?
import clr
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import BuiltInCategory as Bic
from Autodesk.Revit.DB import FilteredElementCollector as Fec
from Autodesk.Revit.DB import Transaction
import Autodesk.Revit.DB
docs = __revit__.Application.Documents
fmi = docs.ForwardIterator.__self__.GetEnumerator()
while fmi.MoveNext():
	curDoc = fmi.Current
	if (curDoc.Title.Contains("BASE")):
		destDoc = curDoc
	else:
		sourceDoc = curDoc
columns = Fec(sourceDoc).OfCategory(Bic.OST_Columns).WhereElementIsNotElementType().ToElementIds()
txSource = Transaction(sourceDoc, 'Copy Columns')
txSource.Start()
txDest = Transaction(destDoc, 'Copy Columns')
txDest.Start()
ElementTransformUtils.CopyElements(sourceDoc, columns, destDoc, Transform.Identity, CopyPasteOptions())
txSource.Commit()
txDest.Commit()
 I am using IronPython in RevitPythonShell.
Revit 2021.1
Windows 10
1 REPLY 1
sedober
in reply to: erron_e
The CopyElements() method uses the Revit Internal Origin as the reference for copying between documents. If you want to use the Project Base Point instead you need to supply a different Transform argument to the method. To do this I'd recommend getting the XYZ locations of the two Project Base Points and then creating an XYZ vector from the sourceDoc's Project Base Point location to destDoc's Project Base Point location. Supply that vector to the Transform.CreateTranslation() method and use that in place of Transform.Identity in the CopyElements arguments.
