Copy a rebar shape 77
sizy458
sizy458
Hello ,
this code for remove and recreate rebar work but
it's don't work with rebarshape '77'
I should delete and recreate entity of rebarshape '77'
Code:
public Result Commande5(
       UIApplication uiapp, object model)
                var rborg = TcmPick.saisiracier(uiapp.ActiveUIDocument, "ttt2"); ///Work !
                Document doc = rborg.Document;
                Transaction trans;
                trans = new Transaction(doc);
                trans.Start("delrebar");
                var cx = HelperRevit1.RevitHelper_GetComputeDriving(rborg).ToList();
                var normal = HelperRevit1.HelperRevit_GetNormalRebar(rborg);
                var shapeid = HelperRevit1.HelperRevit_GetShapeID(rborg);
                var rbshape = doc.GetElement(shapeid) as RebarShape;
                var start = rborg.GetHookTypeId(0);
                var end = rborg.GetHookTypeId(1);
                RebarHookType startHook = null, endHook = null;
                if (start != null)
                    startHook = doc.GetElement(start) as RebarHookType;
                if (end != null)
                    endHook = doc.GetElement(end) as RebarHookType;
                var startHookOrient = rborg.GetHookOrientation(0);
                var endHookOrient = rborg.GetHookOrientation(1);
                var rbbtype = doc.GetElement(rborg.GetTypeId()) as RebarBarType;
                ElementId hostId = rborg.GetHostId();
                doc.Delete(rborg.Id);
                trans.Commit();
                trans.Start("addrebar");
                var host = doc.GetElement(hostId);
                var rbdst = Rebar.CreateFromCurvesAndShape(doc, rbshape, rbbtype, startHook, endHook, host, normal, cx, startHookOrient, endHookOrient);
                //rbdst.RebarShapeId = shape77.Id;
                trans.Commit();
                // testinternet(uiapp, model);
                return Result.Succeeded;
 internal static IList<Curve> RevitHelper_GetComputeDriving(Rebar rb)
#if v2019
            RebarShapeDrivenAccessor rbaccessor;
            rbaccessor=rb.GetShapeDrivenAccessor();
#endif
#if v2019
            return rbaccessor.ComputeDrivingCurves();
#else
            return rb.ComputeDrivingCurves();
#endif
 internal static XYZ HelperRevit_GetNormalRebar(Rebar rb)
#if v2019
            return rbaccessor.Normal;
#else
            return rb.Normal;
#endif
   internal static ElementId HelperRevit_GetShapeID(Rebar rb)
#if v2019
           return rb.GetShapeId();
#else
            return rb.RebarShapeId;
#endif
Thank
jeremytammik
Dear Sizy,
Sorry, that nobody has been able to help you so far. I don't know either, so I passed on your query to the Revit Structural development team.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jeremytammik
The development team replied:
Please provide a complete minimal reproducible case for deeper analysis:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Rebar shape 77 looks like a spiral which means it is a 3d shape. The method  Rebar.CreateFromCurvesAndShape works only with planar curves. This means that the 3d rebars can’t be created with this method.  You should use Rebar.CreateFromRebarShape for that. We also have a sample which does this, c.f. the NewRebar folder  and search for RebarShapeDefinitionByArcType.Spiral.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
