Converting of Revit 2021 project to Revit 2020
OmarBTP38K
Observer Observer
OmarBTP38K
Observer
Observer
is it possible to convert or open the project file Newer version to an older version? (Revit 2021 to Revit 2020)
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @OmarBTP38K ,
Please take a look at this below link
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Backwards-...
In the above link, you will find one workflow to achieve the functionality you want.
1)Open the RVT/RFA file in the newer version of Revit.
2)Export to an IFC (only available for RVT files) or DWG. This export process converts the geometry in the file into a format that can be imported into the earlier version.
3)Open/Import the IFC or DWG into the older version of Revit.
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
