convert to survey points
What is the formula to convert  revit points to survey points. The problem is that when I am exporting a sheet to dwg revit is not taking survey points;inspite of me telling revit to use shared coordinates in the export procedure . Before members jump to conclusions I am doing this via code.
Thanks & Regards
Sanjay Pandey
mikako_harada
Hi Sanjay,
Could you try looking under
ProjectLocation >> < Internal nnnn >  >> Transform >> Origin?
I did some digging using Revit Lookup tool.  That value seems to indicate the location of Survey Point.
Mikako Harada
Developer Technical Services
Thanks Will surely try this.
