Convert Selection to FilteredElementConnector?
wils02
wils02
Okay here goes nothing:
I am trying to implement the PickBox example that is commonly shown http://help.autodesk.com/view/RVT/2014/RUS/?guid=GUID-97372731-5ACA-4EB7-ABDF-7E6B56640DA2
with the idea to select multiple elements at the same time and then use a FilteredElementCollector to make sure I only retain supply air terminals.
For the life of me, I cannot figure out how to do this, and any help would be greatly appreciated!
wils02
arnostlobel
Hello Wils02:
One of the FilteredElementCollector constructors takes a list of element Ids. If such a list is provided then the collector will filter the given elements only, Thus if you get a list of elements from the Selection object, pass it over to the collector. That should do the trick you're after.
Arnošt Löbel
wils02
AWesome thanks for the reply. That makes sense and I will give that a shot.
