Convert Global Coordinate to Revit Local Coordinate
ahmed.gameel
ahmed.gameel
Hello All.
I Have a group of points Collected from Gis Data. These points are in A Global Coordinate. What i need to do is to create
instances from these points to a special type of family I created...
My Question is while I'm creating these instances how to locate them in The Revit local Cooridnate(transform the Global cooridnates for the points to Revit Local Coordinates)
//XYZ tPoint = item.coordinates; //GLobal Coordinates
FamilyInstance new_instance = doc.Create.NewFamilyInstance(tPoint, familySymbol, StructuralType.NonStructural);
Mohamed_Arshad
HI @ahmed.gameel
Revit Local values are in Feet, I think your GIS Data in some other units. Kindly convert into Feet. And pass the value to XYZ Point .Use below methods for conversion.
https://www.revitapidocs.com/2020/86d6d8b7-71ff-3768-4ffd-08969866dd62.htm
Hope this Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
ahmed.gameel
yes i convert the data from the gis data units to revit current unit..but still not accurate number because the difference in coordinates
jeremy_tammik
You also need to take the project location settings into account. They add another transformation between global world and local project coordinates. For an example, please refer to the DirectionCalculation SDK sample:
https://www.google.com/search?q=DirectionCalculation&as_sitesearch=thebuildingcoder.typepad.com
