Convert Directshape to solid
CBSVN_V_QUYET
Message 1 of 9
CBSVN_V_QUYET
Is there any way to convert directshape to solid?
Replies (8)
Message 2 of 9
Mohamed_Arshad
Hi @CBSVN_V_QUYET
  There is no Direct method to convert the direct shape to Solid. We can use Element.getGeometry(option) method.
though iteration process From GeometryElement to GeometryObject -->we can able to find the SOLID.
Please check the below Code for additional reference.
Options opt = new Options();
            opt.ComputeReferences = true;
            GeometryElement element = directShape.get_Geometry(opt);
            Solid solid = null;
            foreach (GeometryObject obj in element)
                if (obj is Solid)
                    solid = obj as Solid;
Hope This Helps!!!
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 3 of 9
CBSVN_V_QUYET
hi @Mohamed_Arshad
Thank you
Use this way it always returns null
Message 4 of 9
Mohamed_Arshad
HI @CBSVN_V_QUYET
Try to get DirectShape Element from outside the transaction by using its ElementId or Element Name.
Or Can you send me your code snippet?
So that i can check why null is returned.
Mohamed Arshad K
Message 5 of 9
CBSVN_V_QUYET
hi @Mohamed_Arshad
I think the problem is that DirectShape returns Mesh but not Solid
Message 6 of 9
Mohamed_Arshad
Hi @CBSVN_V_QUYET
For this Case My Suggestion :),
Check with the Revit Lookup, After creating or selecting the DirectShape.
Mohamed Arshad K
Message 7 of 9
CBSVN_V_QUYET
I also followed your suggestion but actually the result is mesh
Message 8 of 9
CBSVN_V_QUYET
hi @Mohamed_Arshad
Thank you, I modified it a bit according to your code
GeometryElement element = el.get_Geometry(opt);
Mesh mesh = null;
if (obj is Mesh)
mesh = obj as Mesh;
Message 9 of 9
Mohamed_Arshad
Hi @CBSVN_V_QUYET
    If your problem is solved, Please accept it as a solution, In the future, it may be easy for other people facing same
problem.
Thank you so much... 🙂
Mohamed Arshad K
