Message 1 of 10
Conversion from Fixture unit to L/s
I want to do edits in flow conversion method in Revit, Revit is using IPC 2012 tables in the conversions from Fixture unit to L/s. In flush tank systems there is no problem, the problem exists in flush valve system.
Revit converts any value below 5 FU in flush valve system to 0.95 L/s even if this value is equal to 1 and this value "0.95 L/s" for 1 FU is very very high.
I want a plugin to do a conversion for flush valve values less than 5 FU in flush valve systems to be similar to the conversion in flush tank system.
Can anyone help me in this issue?
Thanks in advance.
