Conversion from Fixture unit to L/s
IslamSakr
Message 1 of 10
IslamSakr
I want to do edits in flow conversion method in Revit, Revit is using IPC 2012 tables in the conversions from Fixture unit to L/s. In flush tank systems there is no problem, the problem exists in flush valve system.
Revit converts any value below 5 FU in flush valve system to 0.95 L/s even if this value is equal to 1 and this value "0.95 L/s" for 1 FU is very very high.
I want a plugin to do a conversion for flush valve values less than 5 FU in flush valve systems to be similar to the conversion in flush tank system.
Can anyone help me in this issue?
Thanks in advance.
Replies (9)
Message 2 of 10
IPC 2012 doesn't provide values for flush valve systems with fixture units less than 5 because 5 is the lowest fixture unit count you can have in a flush valve system (1/4" urinal flush valve). In your example, a 1 fixture unit flush valve system doesn't exist as defined by IPC 2012.
If you want a plugin to convert fixture units for flush valve systems with less than 5 FU you're going to have to come up with your own table, and then I believe it's pretty trivial to multiply the FU by your table value.
Message 3 of 10
IslamSakr
When i have lavatory connected with flush valve system, the lavatory has 1 FU, how can i calculate the flow of this lavatory if one lavatory with 1 FU give me flow of 0.95 L/s in Revit conversion,, this is unreal ,, i want to make a plugin to just convert FU less than 5 to L/s equal to L/s used in flush tank table, this will result in logic flow for 1 Lav. till 5 Lavs.
Message 4 of 10
IslamSakr
Any body can help !
Message 5 of 10
jeremytammik
Dear Islam,
Sorry nobody answered yet.
Maybe nobody knows.
I'll pass it on to the development team and see whether they can suggest anything.
On second thoughts, re-reading this thread, I do not see anything here that I can ask the development team.
Matt seems to know what he is talking about in his suggestions above.
Just as he says, the conversion itself is probably a trivial multiplication, and if you need values outside the range of existing tables, you will have to create your own.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 6 of 10
IslamSakr
Thank you Jeremy, yes i want to create my own but i can't, can you help?
Message 7 of 10
jeremytammik
No, sorry, I don't know how and have many other things to do. Sorry.
Jeremy Tammik
The Building Coder
Message 8 of 10
IslamSakr
Message 9 of 10
Jeremy,
You may want to get your keyboard checked out. It typed "No" when it should of typed, "I already did that here: https://forums.autodesk.com/t5/revit-api-forum/usermep-calculation-addin/td-p/4968174 "
Either that or it's a typo. Very common, the keys are right next to each other.
Message 10 of 10
jeremytammik
Hi Matt,
Thank you very much for pointing that out!
I urgently need a full replacement of my memory chips, as well.
That is why I would like to focus more on Q4R4 than on answering cases:
http://thebuildingcoder.typepad.com/blog/2017/03/q4r4-revit-api-question-answering-system.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
